Sponsored by: CARiD
i may have found a way to save fouled spark plugs!!!!
Old Dec 8, 2004 | 08:29 AM
Whizbang's Avatar
Respecognize!
Thumbs up i may have found a way to save fouled spark plugs!!!!
through the mad powers of the Mac tools guy, i found an air powered spark plug cleaner thing! I am going to test it to see if it works on our "special" plugs. I hope it does. i would be the best 60 bucks i ever made my boss spend. ill find out ASAP.
Old Dec 8, 2004 | 09:11 AM
Tom93R1's Avatar
gross polluter
My plugs wear out before they foul from build up, but since it is your boss' money then may as well test it
Old Dec 8, 2004 | 09:13 AM
Whizbang's Avatar
Respecognize!
from the context of all of the threads were some one says they flooded and the first thing some one replys is "get new plugs!" no, your original plugs might still be fine. You must clean them.
Old Dec 8, 2004 | 12:17 PM
edmcguirk's Avatar
Those tools can make your spark plugs nice and shiney but they cannot fix the blunted and worn down center electrode. As a matter of fact they wear it down a little more during the cleaning process.
They can unfoul a plug but they wear the plugs out in the process. I guess it's ok for new plugs that got fouled. Older plugs should probably be replaced anyway.
Old Dec 8, 2004 | 07:40 PM
RETed's Avatar
That only "cleans" spark plugs, but I don't think it'll ressucitate spark plugs that are fouled beyond use.
Fuel soaks into the center electrode, and this prevent current from passing.
Best (and easiest) method I know of of trying to get these fouled spark plugs to revive is to burn the tips off.
Propane torch the tips until glowing red / orange.
BE VERY CAREFUL HANDLING THEM - THE ENTIRE SPARK PLUG IS HOT!
Let cool.
Test for spark.
If you see spark, reinstall.
The spark will be weak, but it should "self clean" after a few miles.
-Ted
Old Dec 8, 2004 | 09:55 PM
patman's Avatar
Resident Know-it-All
yeah...i burn em.
another point...ususally what kills them is not fuel 'soaked in', but fuel/oil/carbon built up on the ceramic insulation around the center electrode causeing a short between the center and outer part, thus no spark.
pat
Old Dec 9, 2004 | 09:49 AM
SnowmanSteiner's Avatar
Ga-nome liberator
Just make friends with someone at Advanced Autoparts. NGK plugs come with a 2 year limited waranty. I replaced my plugs at least 7 times last year and never had a problem at Advance. I was tuning and working out problems hence why I went through so many.
- Steiner
Old Dec 9, 2004 | 12:05 PM
patman's Avatar
^^^ hehe me too. advance ppl dont care, they'll replace em all you want.
Old Dec 9, 2004 | 12:21 PM
cds00bsmg's Avatar
Resident autoglass pro
And you didn't know they make spark plug blasters? I have one of those things from like the 50's sitting out in the garage. As also stated burning the tips with a torch can also aid. However nothing beats getting new plugs.
Old Dec 9, 2004 | 02:40 PM
BASTARD's Avatar
your better off baking them in the oven..then to put sand in your motor
Old Dec 9, 2004 | 09:51 PM
cds00bsmg's Avatar
Yea, you can bake them as well. The plug blaster we have right now has two switch functions on it, sand blast, and air blast, thus preventing any sand from being lodged in the plugs. The FSM says not to use a plug blaster for exactly that reason though.
Its kind of a ghetto way of doing things IMO, but if you don't have the $$ for plugs it sure helps out.
Old Dec 10, 2004 | 12:52 PM
diabolical1's Avatar
burn them or bake them - that's what i do whenever i used to run out of spares.
Old Dec 10, 2004 | 07:50 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
at $5 each i just replace them.
Old Dec 13, 2004 | 08:47 PM
cds00bsmg's Avatar
alex:
http://gprime.net/flash/postingandyou.php
enjoy
Old Dec 13, 2004 | 09:23 PM
patman's Avatar
bwahahahahaha...damn i definately gotta save that one.
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
Joe428
16
Aug 19, 2015 06:24 PM
