Power FC J&S Vs. Knock sensor readings
Old Dec 7, 2001 | 07:16 PM
machinehead's Avatar
kortez
You guys with J&S, how does your readings compare the the commander display knock readings? I have tried a few different things, including a new knock sensor but my readings are kinda high, I have richened the mixture and retarded timing but it didn't really seem to make a difference. My readings are only high under no load, like crusing on the freeway, as soon as the boost comes on they drop. I also tried rapping on the engine with a hammer with the key on engine off and at idle to see if the display changes and it does nothing...
Thanks,
Cliff
Old Dec 7, 2001 | 11:16 PM
cewrx7r1's Avatar
Eye In The Sky
The J&S does not show or give any knock reading or level.
It only displays when it is retarding and then only lights up some LEDs.
Old Dec 10, 2001 | 07:49 AM
KZ1's Avatar
KZ1
from my understanding high readings off WOT is normal, you shoudl only be concerned when at WOT. THe rest do not matter. I see readings sometime as high as 80, mostly about 65 just toling around.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
doritoloco
Sep 5, 2015 12:41 PM
83revival
Sep 3, 2015 10:42 PM
