ADD Coolant light won't go away
The 'add coolant' light in my SE comes on and off intermittently as I drive. I topped it off the other day but it didn't take much. I let it run to normal temp and turned on the heater and added as required. If I rev the engine with the radiator cap off the coolant level goes down but then overflows when i let off the throttle.
Is this just air in the system and if so how can I get rid of it? Or, is this a sign of dowel pin failure coming on....?
Right on.
Right on.
I know before, someone mentioned about filling on an incline or just parking on an incline with the engine running to help get them out, otherwise it just took a little to to come out itself.
Originally Posted by Chamele03
I don't know about the SE but on all of my SA's the wire for the cooant level sensor ( comes out of the top of the radiator) just breaks off or gets disconected very easy.
HA, mine just started that **** yesterday, I figured that sensor up top of the radiator went shot my self. Damn I havent been over here in months whats goin on people? Ive been at NoPistons for God knows how long.
top off the radiator and fill the overflow bottle half way. sometimes the coolent sensors get a film over them, remove the sensor , clean it, install. it's when the engine is burning the coolent( have to add coolant often) is a seal failure.
Trending Topics
The SE doesn't have a low coolant buzzer like an FC has does it ? That would be really shitty....
I have an SE but my coolant light has never come on in all 200 miles I've driven it
--Alex
--Alex
I once had a kinked coolant line going to my beehive oil cooler. The add coolant light kept coming on even though the level was good. I replaced the kinked hose and the issue was resolved. Might be worth checking this out. Good luck...
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
My 85 GSL does the same thing. Also has the added 'bonus beeper' that goes off when the sensor activates. I hate the SOB but don't really want to disable the feature.
alphawolff
Nov 17, 2015 05:57 PM
rocker1337
16
Sep 6, 2015 11:28 PM
RPOdesign
Aug 27, 2015 11:42 PM
