Turbo Timer Install
Old Dec 5, 2001 | 06:30 PM
Question Turbo Timer Install
I'm sure this has been posted many times b4, but I can't seem to find it.... Anyways, I just bought an A'PEXi turbo timer and am looking for a place to connect to the parking brake switch.
I also purchased the Greddy turbo timer harness (to make life a bit easier), does anyone know what the three extra leads are for?
Old Dec 5, 2001 | 10:34 PM
7-sins's Avatar
thats not paint....
Hmm.. well lets see here. The parking brake switch is pretty cut an dry, If you have a manual it's hard to get confused. If you remove the plastic trim on the center console you can see the wire comming out of the handle. As far as the harness... The three wires comming off might be for the timer, one possibly a ground.
Hope it helps,
Chris
Old Dec 5, 2001 | 10:55 PM
jr's Avatar
jr
3 extra leads (if I remember correctly) Ground, Parking Brake, Speedometer. The speedo input is an extra level of protection, if it registers the car moving it'll shut it off.
Old Dec 6, 2001 | 11:53 AM
Apparently the three extra wires are for accessory use (I had one of my Japanese friends translate the instructions)
As for the parking brake switch - Is there any way to connect it without removing the center console??
Old Dec 6, 2001 | 02:51 PM
7-sins's Avatar
thats not paint....
You dont have to remove the whole center console just pull out the plastic trim on it. There should be 3 or so clips holding it on so just pull up on it with some force.
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
