Power FC Commander Questions
Old Oct 21, 2004 | 01:15 AM
Commander Questions
ok, this is my first day with the commander in my car. How do I get the menu screen to highlight the options on the left side with speed and RPM instead of just the right side with knock and air temp.?
Sorry if this is a stupid question. I did some searching and didn't come up with anything useful.
Old Oct 21, 2004 | 07:38 AM
cewrx7r1's Avatar
Eye In The Sky
I do not understand your question.
What menu screen are you talking about, and what are you trying to do?
Old Oct 21, 2004 | 03:20 PM
rynberg's Avatar
Rtfm
Old Oct 21, 2004 | 05:15 PM
allenhah's Avatar
Dirty
Like Ryan said...or do what I did when I first got it...just hit the buttons...you'll figure it out eventually.
I *think* what you're asking is how to select the sensor that you want to monitor? If that's the case, you should be able to just hit the "prev" button, which should eventually take you to the screen that allows you to select the things you want to monitor. If you go "prev" once more, you'll be able to choose the number of things you want to monitor.
Should be pretty easy from there.
If that's not right, please rephrase the question.
Old Oct 21, 2004 | 05:28 PM
cewrx7r1's Avatar
Eye In The Sky
Here, read the manual.
Yeah, be sure to download and print it off.
http://www.spipowerexcel.com/pdfs/fc_commander_fd3s.pdf
Old Oct 22, 2004 | 04:35 AM
badddrx7's Avatar
All Spooled Up
Anyone got a link to the ECU install manual in English ?
Tom
Old Oct 22, 2004 | 10:51 AM
allenhah's Avatar
Dirty
I believe it's in the sticky in this forum...
Old Oct 22, 2004 | 03:29 PM
thanks guys for the manual. Ended up having a defective unit. Problem solved
_Tones_
May 25, 2021 05:37 AM
