Got a 7, need rims
Old Oct 17, 2004 | 07:04 PM
Psycho3's Avatar
Got a 7, need rims
This is my first post so let my introduce myself. My name is Matt and i'm 17. Just bought a 1987 rx-7 and it only came with some steelies and winter tires. I need a wheel/tire combination for next summer and was wondering if I could get some help.
The choice is between the MB motorsports weapon and the 5Zigen FN01R-C
I would like to know what sizes would look and fit best. I've read about 17X7, 17X8, and 17x9's and have all had mixed answers. I would like to leave the fender lip as it is and not have to roll it up. If someone could point me in the right direction it would be greatly appreciated thanks.
Old Oct 17, 2004 | 07:17 PM
satoacs's Avatar
if it was out of those 2 i like the MB motorsports weapons, 17s are a good choice, might want to go with a lil wider tires in the bak.....maybe 17x8front and 17x9rear
as ppl have told me, dont go with what people think, go with what you like best. just a lil advise.
Old Oct 17, 2004 | 07:54 PM
Psycho3's Avatar
thanks
Old Oct 17, 2004 | 07:57 PM
satoacs's Avatar
wait a few days and the experts will get to your thread
there are a few that i know of on this forum, dont remember their names right now, but ill look later on if u still need help.
oh and it would also help to state what you are looking to do(i.e. speed for the city or track, handling in turns, daily driving with bling rims, etc.) there are many factors that can play a roll in this.
Old Oct 17, 2004 | 10:36 PM
Black91n/a's Avatar
Unless you have lots of power then it's best to use the same size tire for the front and rear for good handling, otherwise you'll never be able to get it to do anything but understeer (plus you can rotate them if you use the same size). 225/45/17 is about as big as you can go in the front with the stock suspension (coilovers are narrower and give more room on the inside). Some people are able to use 235/40/17's on the front without coilovers, but there's a risk of severe rubbing on either thr suspension or fenders. I've got 225/45/17's on 17x8" Mustang GT wheels and they fit perfecly, and give good handling at the limit (on a racetrack of course, driving 10/10ths on the street is STUPID!). If you have a TII then maybe a little wider in the rear is good, like a 245 or 255 on a 9 inch wide wheel. For 225's a 7.5 inch wide wheel is ideal, but you can use anything from 7 to 8.5 (check the tire manufacturer's reccomendations). For offsets you should get something in the order of 25-32mm for a 8 inch wide (the Mustang GT wheels are 30mm and fit perfectly).
Do a search, look at the official FC wheel fitment guide thread, and listen to RETed, he knows his stuff.
Old Oct 17, 2004 | 10:45 PM
karken29's Avatar
bump
Old Oct 17, 2004 | 11:45 PM
Psycho3's Avatar
thanks satoacs you have helped out a lot.. u pretty much answered all my questions.
I think i'm gonna go with some mb motorsports (a-tech) weapons.. 17x7.5 front and rear and go with the tire specs that u provided.
Old Oct 17, 2004 | 11:53 PM
satoacs's Avatar
no problem
i just read up on aftermarket tire sizes on a couple other threads and found some that said 18s would rub a lot, so its a good choice to go with 17s
Old Oct 18, 2004 | 06:57 PM
Psycho3's Avatar
scratch that, found out I've only got 4 lug hugs, not 5
Old Oct 19, 2004 | 12:38 AM
Black91n/a's Avatar
All of the specs still apply, just make sure the wheels have the 4 lug pattern (4x100 I beleive, but don't quote me on it).
Old Oct 19, 2004 | 01:10 AM
Psycho3's Avatar
I believed it was 4x114.3?
Old Oct 19, 2004 | 09:15 AM
zinx's Avatar
_________________________
its 4x110 for the 4 lug FCs, i think, but i'm going to look it up
Old Oct 19, 2004 | 09:18 AM
zinx's Avatar
ok, maybe it is 114.3mm
Old Oct 19, 2004 | 06:18 PM
Black91n/a's Avatar
I was wrong.
From the FC FAQ:
What size are my wheels?
The stock sizes all have an offset of 40mm or 40 ET and are:
14x6 w/ 114.3x4 bolt pattern (Base, Luxury, 87.5-88 SE)
Old Oct 19, 2004 | 08:29 PM
RETed's Avatar
Fronts...
8" wide, +30
225/45/17
It's all covered in that other "Official..." thread.
-Ted
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
