Sponsored by: CARiD
detonation
Old Nov 30, 2001 | 08:51 AM
wai's Avatar
wai
RX7 club knows about you
detonation
what cause it , and can you feel that when you driving?
Old Dec 2, 2001 | 11:34 PM
tims's Avatar
detonation is the premature cumbustion of the air fuel charge. the air fuel charge in the combustion chamber ignites before the spark plug fires. this can cause apex seal failure, damage to rotor housings, damaged end plates, rotor damage. on the turbo motors it can be caused high air intake temps, boost creep, carbon build up, and advanced timing under boost. most of the time it cannot be heard by the driver and if it can be it will sound kind of like a rattling noise.
Old Dec 3, 2001 | 02:35 AM
HWO's Avatar
HWO
inteligent extratarestril
No, That is actually Pre Ignition.\
Detonation is when combustion occurs at the right time but instead of being a controlled burn, it pretty much explodes in an uncontrolled manor, the only thing controlled about it is when the spark sets it off.
Old Dec 3, 2001 | 05:19 AM
goes-hmmm's Avatar
http://zhome.com/ZCMnL/PICS/detonation/detonation.html
See above link for more information. I could tell you more specific rotary engine information but I'm out of time, shift is almost over.
Th0m4s
Feb 26, 2019 02:04 AM
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
msilvia
15
Sep 11, 2015 12:13 PM
A-Spec
Mar 15, 2002 03:52 AM
