What can I get rid of in the engine bay on a LS-1/FD?
Old Oct 3, 2004 | 10:08 PM
OneBadFox's Avatar
Just trying to find out what all can be removed from the engine bay on a LS-1/FD.
Old Oct 3, 2004 | 11:54 PM
digitalsolo's Avatar
RX-347
...that damned rotary.
Just kiddin'
Old Oct 4, 2004 | 05:37 PM
turbogarrett's Avatar
0 lbs of boost
Cooling fan relays, igniter, engine wiring harness, fuel pump resistor, the rest is up to you. Are you keeping abs, cruise control, ac etc?
Old Oct 4, 2004 | 07:07 PM
OneBadFox's Avatar
Yes I'm keeping ABS, Cruise control and AC, but my question is how can I make the factory cruise control work the LS-1 motor.
Where is the fuel pump resistor?
Old Oct 4, 2004 | 07:14 PM
0 lbs of boost
Don't know about the cruise control, I don't have it, you'll need a longer cable that's for sure. The pump resistor is down under the cruise control module, it's a silver box with heatsinks.
Old Oct 6, 2004 | 12:14 PM
RX-Ben's Avatar
Losing Traction on 335s
I doubt the RX7 cruise control will work since it needs the speed sender from the RX7 transmission. You can probably buy a universal cruise unit from JC Whitney and get that to work.
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
