gram lights...can it fit?
Old Sep 30, 2004 | 02:02 AM
|aFk| LiMiTz's Avatar
rawrrr
Hey guys will 18" gram lights with a offset of 45mm and 8.5 for all fours fit without rubbing issues? I am on stock touring suspension. I know it will fit for the rear but not to sure about the front without rubbing problems. Also whats the widest tire I can fit on these? I hear of people maxing out 245s on the stock 8s, so will 255s-265s fit on these? thanks
-Jon
Old Sep 30, 2004 | 02:44 AM
Rx-7Addict's Avatar
Rotary Powered
-Jon
Id reccomend a 9" wheel for 255-265.. 255 is generally the widest you can go on the front tires, but it really depends on your suspension setup and tire diameter. +45 seems a little high, not 100% sure though
Old Sep 30, 2004 | 02:47 AM
SpeedKing's Avatar
Power Trippin'
-Jon
Yes, 18x8.5 +45 will fit fine, front and rear w/ 235/40-18.
Old Sep 30, 2004 | 02:52 AM
SpeedKing's Avatar
Power Trippin'
With a 9" wide wheel up front, you'd minimally want to run an offset of +45. In a 18x9, I'd recommend 255/35-18.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
