Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
S4 to S5 conversion
Old Sep 18, 2004 | 04:51 PM
rotaryrex7's Avatar
Question S4 to S5 conversion
I have an ITS 2nd gen racecar with a S4 ECU. I would like to convert the electronics to an S5 ecu, maf and injectors to be able to plug and play a spare S5 motor that I am rebuilding. As a racecar all the emissions have been removed so the harness is down to the maf, injectors, cas and tps.
Can I simply bolt in the S5 ECU and use the S5 harness?
Old Sep 18, 2004 | 07:15 PM
Eagle7's Avatar
Others will have to confirm, but I think you need the S5 OMP.
Old Sep 18, 2004 | 08:01 PM
rotaryrex7's Avatar
Not a problem, I have the S5 OMP.
Coochas
44
Nov 5, 2019 11:08 PM
