Horn resistance in CPU??
Old Sep 16, 2004 | 11:21 AM
are_one's Avatar
Back from the dead
Anyone know off hand what it is? I ran my own setup, bypassing the CPU relay, but the horn sounds different. Im guessing that the original setup wasn't putting 12V to the horns, so I was just going to put a variable resistor in line with them.
Old Sep 16, 2004 | 11:28 AM
WAYNE88N/A's Avatar
Since the same power circuit is used for both the relay coil and the horn(s), taking the coil out of the equation will result in less of a voltage drop. Is the horn higher-pitched now?
Old Sep 16, 2004 | 01:19 PM
Icemark's Avatar
How have you wired the bypass??? You need a relay in there, or the horn switch will burn out
Old Sep 17, 2004 | 05:15 AM
are_one's Avatar
Back from the dead
I put a relay in there. I just tapped off the blue/orange wire used to go to the buttons from the CPU relay. I ran this wire to the ground side of the realy. The horn now makes a higher pitch, it sounds kind of funny, I don't like it.
Old Sep 17, 2004 | 09:20 AM
Icemark's Avatar
Well there are no resistors so maybe you wired it funny, or missed one of the horns??
Normally you would bypass the CPU horn circuit with a relay wired like this:
85 to the horn switch wire coming from steering column
86, 87 to 12 volts
30 to the wire running out to the horns from the CPU.
Old Sep 17, 2004 | 11:15 AM
are_one's Avatar
Back from the dead
Thats exactly how I wired it. I noticed the horn units themselves looked rusty, maybe the problem lies in there. thanks for the input
Old Sep 17, 2004 | 11:56 AM
Icemark's Avatar
yeah, check to see the horns are both working
wa11yba11s
Oct 16, 2015 09:54 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
