wanting to buy megasquirt
i was thinking about buying this preassemled megasquirt box... http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
all i need to know is how to use the stock ecu to do the stock timing and retard under boost... if the MS uses all the sensors, and the stock ECU needs those sensors to accurately calculate timing, then how the hell does they both work in sync?
i've been reading about this all afternoon and i cant seem to find any descriptive instructions on how to use this in conjunction with the stock ecu/timing.
How about a modded 12a dizzy that retards boost. Solved.
Hey, if you were a noob, i'd tell you to search. You know its been covered, I know its been covered because I asked the exact same question 2-3 months ago.
Jacobcartmill, when I was running the MegaSquirt on my car I installed seperate sensors just for it. Coolant temp, inlet air temp, tps and of course it's built in MAP sensor.
-John
-John
GrossPolluter
Aug 15, 2015 10:32 PM
