Check out my plugs, look ok?
Old Sep 14, 2004 | 11:25 PM
jon88se's Avatar
Eat, sleep, work, mod.
Well, these plugs have about 2K miles on them since the rebuilt TII motor was installed. I'm running 12-13 psi with a walbro, GReddy FMIC, Rtek7 1.5 ECU, stock injectors and no emissions. EGT's peak @ 700 on my GReddy gauge through a WOT run in third gear.
I think they look damn good if not a tad on the rich side. I replaced these with a set of 9's all around (these were stock plugs, 7 leading, 9 trailing). They didn't need replacing at all but I thought I'd try all 9's out.
Thoughts?
Old Sep 15, 2004 | 12:09 AM
Icemark's Avatar
looks very rich on the rear rotor, and a little clogged and worn for 2K miles... but otherwise they look fine.
I would have guessed 5-8k miles on the leadings by the way they look.
Old Sep 15, 2004 | 07:14 AM
Kenteth's Avatar
Like Ghandi with a gun
Reminds me mark, you get set up to deal NGK plugs yet?
Old Sep 15, 2004 | 07:28 AM
SureShot's Avatar
Seduced by the DARK SIDE
It looks like these plugs were in during the easy driving break in period where they accumulated more than normal deposits.
Then when you started to run up the power the deposits started to burn off.
I suspect your tune is pretty good.
To get a good plug read, clean them & run them again, then recheck them.
PS: When I tried 7's in the trailing position, they fouled.
Old Sep 15, 2004 | 08:30 AM
Icemark's Avatar
I have leadings in the regular NGK available right now
Old Sep 15, 2004 | 08:45 AM
Kenteth's Avatar
They're on your site? K, I'll check later today
Old Sep 15, 2004 | 08:51 AM
jon88se's Avatar
I'm running all 9's now, I'll pull them in another 1K and see how they look. After the first day or two of running/idling once the rebuild was first started/installed, the set of plugs pictured were installed and I started driving the car for break in. I changed the oil @ 500 miles, added some boost around 800 miles and full boost/revs around 1100 miles since the motor felt strong and started consistently. This motor never had any flooding issues throughout the entire break in. I had 2 floods last week, both on hot starts on muggy humid rainy days. I found a vacuum leak in the TID and changed my very old spark plug wires and it's been 100% again ever since, hot starts and all. So, these plugs were in the car since the motor had like 5 miles on it I'm pretty happy with the way they look as well as the motor/swap in general. BTW, this is one of Kevins rebuilds/streetports from rotaryresurrection.
Old Sep 15, 2004 | 09:09 AM
Icemark's Avatar
Should be about half way down this page:
http://www.mazdamark.com/prod01.htm
Old Sep 15, 2004 | 08:20 PM
jon88se's Avatar
Why would you put hotter plugs in the trailing?
Old Sep 15, 2004 | 10:58 PM
FC3S Drift's Avatar
7 UP URS!
do the numbers derive from the part number of the plug? ex. 7 = BUR7EQ
and whats the advantages of running all plugs with 9? or 7?
Old Sep 16, 2004 | 12:09 AM
beefhole's Avatar
Boosted. I got BLOWN!!!
Yes that's where the #'s 7 and 9 come from.
On turbo motors you might want to run a cooler plug (9's in this case) if it's been modded a little (like jon88se is doing).
As far as the stock motors 7L and 9T that's probably the best setup.
Old Sep 16, 2004 | 01:33 AM
Impreza2RX7's Avatar
Yeah, I agree, if you have a moderately modded car, you should run all 9s.. The 7s are just in there for emissions purposes..
rocker1337
16
Sep 6, 2015 11:28 PM
TheAsset
Sep 5, 2015 04:36 PM
PhillyFC
Aug 21, 2015 06:36 PM
