How to install an after market Steering wheel ???
Old Sep 14, 2004 | 02:59 AM
Rotary_7's Avatar
Talking How to install an after market Steering wheel ???
How do i install a after makrjet steering wheel???
I am bout to buy a Nardi Steeringwheel with a nardi hub...how do i install it?
Any picture guides???
What kinda of screws do i use??? Do i use the ones frum tha stock OEM wheel???
BTW: Its not illegal to change your steering wheel ryt?
Old Sep 14, 2004 | 03:24 AM
-TAL-'s Avatar
heres how it will work.
You remove your steering wheel horn cover ( 2 screws if i remember correct, and take off the horn cover)
You'll see a big nut threaded onto the steering shaft. Take that off, then pull like a **** to get the wheel off, it will be very hard, or buy a steering wheel puller set (should be cheap, like 10 bucks)
The aftermarket steering wheel should come with the screws to mount it to the hub, then the hub just slides on like the original did, and VOILA!
That should be it
Old Sep 14, 2004 | 07:04 AM
rmills1276's Avatar
zoom zoom in da boom boom
hmmm... i just paid the guy at tuffys 30 bucks under the table
Old Sep 14, 2004 | 07:21 AM
crashdummy's Avatar
ok you cut the old one off ..
next take the new steering wheel and stick it where the old one was using super glue and some duct tape if you need it.
Old Sep 14, 2004 | 07:25 AM
Bukwild's Avatar
I am buying a new steering wheel and getting the security feature of taking it out of the car when I am not driving it.
Old Sep 14, 2004 | 07:42 AM
E6KT2's Avatar
When doing it without a puller, do not fully remove the nut. That way when the wheel finally give you will not smack yourself in the face with it. Steering wheel removal has caused many busted noses.
Old Sep 14, 2004 | 03:34 PM
rx7jake's Avatar
blah
rent a puller from autozone. why buy one, its only going to be used once.
Old Sep 14, 2004 | 05:19 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
You will probably need an RX-7 "steering wheel installation kit" if your aftermarket steering wheel isn't made specifically for RX-7s. Most auto parts stores should have them. It will have the piece with the ridges that fits over the steering wheel rod that adapts to your steering wheel base.
Old Sep 14, 2004 | 05:29 PM
Icemark's Avatar
everyone is forgetting that the turn cancel/wheel position switch is behind the stock wheel. make sure the aftermarket wheel has the correct adapter to match up to the two guide pins for the wheel position switch.
Old Sep 14, 2004 | 06:34 PM
Kenteth's Avatar
Like Ghandi with a gun
lol, speaking from experience eh?
Old Sep 15, 2004 | 12:22 AM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Quick release hub? What kind and how much did that cost you?
Old Sep 17, 2004 | 01:54 AM
Rotary_7's Avatar
so i try to pull it off wit brute force???
Old Sep 17, 2004 | 02:31 AM
eriksseven's Avatar
Make Money.
Yes, wiggle and pull it with brute force. REALLY don't forget to leave that nut on there for your protection when pulling on it.
Old Dec 24, 2007 | 09:30 PM
K!NCH's Avatar
Im thinking of getting a Nardi wheel and a works bell short hub. Do I need anything else?
Old Dec 24, 2007 | 10:44 PM
MaczPayne's Avatar
Mac Attack
Holy **** revival.
Old Dec 24, 2007 | 11:30 PM
metal's Avatar
Sewww Speciellllllll
Woooooooooow.
Old Dec 25, 2007 | 12:04 AM
farberio's Avatar
NASA-MW ST4
At least we know he searches!
Old Dec 25, 2007 | 12:37 AM
CarzArKoo1's Avatar
1st. take the horn cover off, 2nd take the nut that attach to the steering wheel,3rd then go rent a steering wheel puller from autozone. 4th install the right hub on your rx7 and then put the nut back on and tighten and torque it to 32, forgot ask around, then get a quick release or just get a aftermarket steering and attach screw around the hub. Done!
Th0m4s
Feb 26, 2019 02:04 AM
