First Start on the new engine with single turbo...
Old Sep 13, 2004 | 03:19 PM
modrx7's Avatar
First Start on the new engine...
I am running a single turbo, with necessary supporting mods. What plugs should I run, to break in and get it started.
-Edan
Old Sep 13, 2004 | 03:57 PM
XSTransAm's Avatar
Ee / Cpe
5483
ngk-bur9eq
Old Sep 13, 2004 | 04:05 PM
modrx7's Avatar
Any place that sells these online for cheap... And is not a scam
Old Sep 13, 2004 | 04:39 PM
zayrx7's Avatar
the mazda zoom zoom store
www.rx7store.net
Old Sep 13, 2004 | 05:21 PM
XSTransAm's Avatar
Ee / Cpe
5.25 each at your local advanced auto, every one ive been to has them in stock
Old Sep 14, 2004 | 06:28 AM
modrx7's Avatar
should I run these in both the trailing and leading... to start
Thanks for you help
Old Sep 14, 2004 | 08:11 AM
XSTransAm's Avatar
Ee / Cpe
i run both in trailing and leading all the time, they are the stock trailing plugs which are colder than the stock leading plugs, the stock leading plugs are 7's... i have run the 9's all around in my car for a long time, and so have many others.
Old Sep 14, 2004 | 10:00 AM
modrx7's Avatar
Alright, thats what I'm getting then, thanks
Old Sep 14, 2004 | 10:47 AM
zinx's Avatar
_________________________
I'm totally guessing here, but for the very first startup, wouldn't it be easier to use fairly hot plugs, like 6s or 7s, just to get it to fire up for a few mins. After its been started a few time switch to a colder plug.
And actually you are probably alright running a hotter plug during break-in when you are out of boost.
Old Sep 14, 2004 | 11:34 AM
XSTransAm's Avatar
Ee / Cpe
broke mine in with 9's. it started the second crank.
Old Sep 22, 2004 | 10:42 AM
modrx7's Avatar
What does leading and trailing mean... Are the leading plugs the ones closer to the top of the engine, and the trailing plugs the ones closer to the oil pan?
Old Sep 22, 2004 | 11:58 AM
Zero R's Avatar
Just in time to die
Look on your housings it will tell you which are which, your starting to scare me over here.
Old Sep 22, 2004 | 01:49 PM
95R2-89TII Ground Zero's Avatar
Banned
Advance Auto Parts............cheap *** NGK's
Old Sep 22, 2004 | 01:51 PM
modrx7's Avatar
Sean, so I am wrong. Well I guess it would have been good, if I made the bbq so I could get that figured out huh...
Old Sep 22, 2004 | 01:57 PM
edv's Avatar
edv
I Like Beer
T = Top = Trailing
L = Lower = Leading
Old Sep 22, 2004 | 03:34 PM
modrx7's Avatar
Thanks..
sherff
Feb 24, 2019 12:09 PM
