Downside to running alchohol injection on a road coarse
Old Sep 7, 2004 | 02:27 PM
radkins's Avatar
I have recently installed a alchohol injection system on my car and am quite pleased with the lower intake temps. I an about to do my first road coarse with it and was trying to think of a downside to running it on the track for long periods of time.
Old Sep 7, 2004 | 02:44 PM
pluto's Avatar
add some of those oil lubricant additive with your alcohol injection. Alcohol tends to make everything dry (including internal engine parts) so you'll most likely get more wear and tear ( I assume).
Old Sep 7, 2004 | 03:31 PM
radkins's Avatar
Maybe some Marvel Mystery Oil 100/1? I aready use a decent amout of this in the fuel, but I guess it won't hurt to use some in the alchohol.
I actually use 1/3 water and 2/3 denatured alchohol.
Old Sep 7, 2004 | 04:31 PM
TrentO's Avatar
I'd be worried about slosh and running out of fluid. If your car has temperature issues when street driving the road course will radically exceed the cooling you have available. I view alcohol / water injection as a temporary band aid solution and the downside of depending on a system which can run empty on you is too large for me to risk it.
-Trent
Old Sep 7, 2004 | 05:10 PM
radkins's Avatar
-Trent
I am not tuned for WI, I use it for a buffer on top of a safe map, and to lower intake temps.
My water temps at the track are always pretty good, but my intake temps would rise to about 55-60 after about 30 min on the track due to my M2 SMIC. I located the main nozzle pre-IC so it would keep the IC cool, and if it failed, my IC would still be cool enough to absorb the heat on its own. I am hoping to be able to keep the temps down to near ambient even after 30 min of track time.
As far a runnimg out of liquid, I have two camp shower bags (one in each rear storage bin) that hold 3 gallons each with no air.
Old Sep 7, 2004 | 06:01 PM
gnx7's Avatar
Pre intercooler?/????? Are you afraid it will puddle/condense on the inside of the intercooler?
All alchy injection setups I've seen are just before the throttlebody as it is airflow related..... The alchy/water mist needs a fairly straight shot into the TB so it doesn't collect on the intercooler piping walls.
I believe when I ran alchy on my car I used stuff called Uplon. Similar to MMO but specifically for use with alcohol.
I'll look it up tonight.
Alchy significantly lowers intake temps... good safety buffer. Also remember colder air inlet temps help tremendously in cooling efforts.
-Mark
Old Sep 7, 2004 | 06:23 PM
radkins's Avatar
I have stage one set to come on at 10psi pre IC, and stage 2 14psi post IC. The velocity seems to pull the liquid through with no problem. The reason I know this is because when I first hooked it up I had a manual activation switch hooked up and was turning the WI on while cruising. I was expecting the car to stall but it didn't. It was collecting in the IC and as soon as I hit boost in 1st gear it all sucked in the engine and I got bad breakup for the first few boosts till it cleared out. Maybe a lightly modded twin setup wouldn't have enough velocity to pull it through, but mine seems to work fine.
Let me know about the lube stuff
-Mark
Old Sep 8, 2004 | 10:38 PM
artowar's Avatar
FD3SW211E55
Originally Posted by radkins
I...As far a runnimg out of liquid, I have two camp shower bags (one in each rear storage bin) that hold 3 gallons each with no air.
If it's a flammable mixture, then I think you are dramatically increasing your risk of a fire inside the cabin. Maybe you can get a fuel cell that will work.
Old Sep 9, 2004 | 01:56 AM
gnx7's Avatar
Looked at it just now.... it is called Klotz UPLON Fuel Lube KL-107
Tech Support line: 219 490-0489
www.klotzlube.com
-Mark
Old Sep 12, 2004 | 01:24 AM
ZeroBanger's Avatar
Ryan,
I dont recommend 100 pct alcohol, run a max of 50 pct. NOTHING prevents detonation and Nothing lowers your intake temps like water.
Alcohol will give a similar effect as race gas, I run some myself but if you develop a leak in your lines....
Old Sep 13, 2004 | 09:45 AM
radkins's Avatar
Originally Posted by ZeroBanger
Ryan,
So why bother running alcohol at all if water is better? I have searched for info on the differenced between running alcohol, water and methanol and found almost nothing.
FWIW my pressure regulator built in my pump is sticking from the alcohol. It shuts the pump offf, but won't turn it back on without taping on it. I bypassed it and am searching for the Klotz lube. Hopefully that will help.
Old Dec 6, 2004 | 11:15 PM
Turblown's Avatar
Turn up the boost
Don't mean to bring up a dead thread, but this was never answered and I'd like to know also. Is it because of the octane raise from alky?
Old Dec 7, 2004 | 11:18 PM
gnx7's Avatar
Water will help stop detonation problems.... alcohol will help to bump up the octane level and stop detonation.
Water injection with the proper fuel in the tank would probably be the best. Steve Kahn (Pluto) can answer this one as he has built a few cars with the Aquamist setup.
You better have a big reservoir if using it on a road race course.
-Mark
Old Dec 8, 2004 | 07:30 AM
cpa7man's Avatar
Racing is life!
-Mark
Yes, and it will also keep it from freezing. I ran water/alch. injection in an old turbo piston car I had. 50/50 is plenty, this was per Corky Bell. Remember there is nothing new here people have been running this stuff for 50+ years.
Th0m4s
Feb 26, 2019 02:04 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
