Haltech CAS MSD magnetic signal stabilizer
Old Sep 6, 2004 | 08:39 PM
FD3S_wanted's Avatar
I bought a E6K that came from a FD. I will use it with my FC powered by a 13B-RE. I will be using stock coil and the RE CAS. The harness came with 2 msd magnetic signal stabilizers (MSD 8509). Should I keep these boxes ? What do they really do ? Will it change the configuration of the E6K ?
Thanks
Alex
Old Sep 6, 2004 | 09:33 PM
enzo250's Avatar
IRS Champion
The msd 8509's are reluctor adapters. What they do is convert a magnetic signal(sine wave)into a digital signal (square wave) so that the ecu can read it.
The E6K has internal reluctors built into it. SO you don't need to use the 8509's.
older haltech's didn't and that why people used them.
Old Sep 7, 2004 | 08:52 AM
Ok but is it better to use since I have them ?
Old Sep 7, 2004 | 06:50 PM
RETed's Avatar
No, it just more **** to fail on you.
-Ted
Old Sep 7, 2004 | 09:19 PM
Thanks I have already removed them.
Devon Murray
Sep 26, 2015 08:15 AM
