Suggestions for cleaning animal carcass off bottom of car
Old Sep 1, 2004 | 10:45 PM
Rattaan's Avatar
we...yota...
Like it says, what's the best way to clean the underside of the car? I believe it's a deer, though it was difficult to tell what the bloody, chunky, skinned, deer-sized pile was on the road in the dark. It smacked the front lower bumper and scraped pretty much the entire underside of the car, leaving stringy meaty, hairy chunks on anything that wasn't a smooth pass over. I don't think I can stand to drive without cleaning it up a good bit first because it stinks to high heaven. Anybody?
Old Sep 1, 2004 | 10:50 PM
WAYNE88N/A's Avatar
Pressure washer? At least your deer was already scrunched, my deer totaled the car 4 years ago
Old Sep 1, 2004 | 10:51 PM
maverick2.0's Avatar
Shadow Rocket
First off, why did u hit it lol...wasnt there a way to miss it? but as far as cleaning it im not to sure... first thing i would prolly try is soap and water but im not that smart when it come to cleaning... i've never hit anything layin in the road.
Old Sep 1, 2004 | 11:02 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
go to an automatic car wash... one that has the sprayers for the bottom of the car!!!
Old Sep 1, 2004 | 11:12 PM
Shadow Rocket
LOL there ya go decay... thats the way...
Old Sep 1, 2004 | 11:14 PM
Rattaan's Avatar
we...yota...
Ok, first thing, thanks to whoever moved this, I didn't think about putting in the right category since I'm usually in the 2nd gen section. Second, I didn't have much choice in hitting it because I was about 3-4 carlength's behind a truck who drove completely over it without touching it(couldn't see it coming ahead of him) and I was beside a pick-up on the two lane road so I couldn't move over either. I was going a little over 65 and braking would have probably made things worse. I'm not sure if a pressure washer would get this junk off, it really got scraped onto the underside. I'm thinking I may have to physically scrape it off by hand. Ugh. Plus it's now pretty well cooked onto the exhaust pipes.
Old Sep 2, 2004 | 12:02 AM
SpeedKing's Avatar
Power Trippin'
Get one of these lawn sprinklers from Sears (about $10), hook it up to a hose, stick it under your car, and leave it there for a while.
Old Sep 2, 2004 | 01:24 AM
marlaman's Avatar
Need an E6x
So keep it that way when you go fast your exhaust will heat up and the ricers behind you will smell yoru stink trail.
that's what i'd probably do because i'm lazy,
Matt
Old Sep 2, 2004 | 07:26 AM
Shadow Rocket
lol im with matt... not many ppl gonna look at the bottom of your car anyway... just let it wear off other then that try the sprinkler deal
Old Sep 2, 2004 | 09:15 AM
Gremlin's Avatar
Part-time Sancho
The best way is to probably do it by hand. At least that way you now some pressure washer jets are not cramming chunks of deer into forsaken areas that you would normally not have a chance of getting into with your hand. The sprinkler idea is pretty good. Just keep it on a low setting and let it sit for a while. Should make removal of the deer quite a bit easier.
cdn
14
Sep 10, 2015 06:23 AM
