17X9 all around?
Old Aug 25, 2004 | 11:11 PM
Versatile's Avatar
17X9 all around?
Is it possible on a 2nd Gen without any problems?
Running stock suspension but will go shock/spring combo in the future
What are the best offsets for the front and rear if I go this route?
Thanks
Old Aug 26, 2004 | 10:51 AM
Endless Work's Avatar
You'll need wide fenders in front. Front would need to be around +15 to +18, IMO with coilovers, this would barely clear depending on the camber you're running.
Old Aug 26, 2004 | 01:21 PM
Versatile's Avatar
What about 17x8 all around, would there be any problems? Thanks for the info
Old Aug 26, 2004 | 07:13 PM
RETed's Avatar
8" wide no problem.
Fronts I would run about +27 to +30.
You can go as tight as +35.
Rears, you can go down to a +10, but if you want symmetrical set-up, identical offsets front and rear will work.
-Ted
Old Aug 27, 2004 | 01:40 AM
Versatile's Avatar
Originally Posted by RETed
8" wide no problem.
-Ted
As for those values that you have provided, that is for x8 all around right? Just wanted to make sure.
What offsets would be best if I went 17x8 and 245 tires all around. Is 245 even safe for the front?
Ted your the man, gotta love them avitars!
Old Aug 27, 2004 | 02:39 AM
RETed's Avatar
If you're looking at identical wheels front to back, then I would try and run 17" x 8" +25 or close to that offset.
I doubt 245's would fit up front.
235's are already kinda tight in the front.
Most 245's won't fit.
Try 225/45/17...
-Ted
Old Aug 27, 2004 | 02:55 AM
Versatile's Avatar
Cool cool thanks Ted...
Gonna try that then, 17x8 all around with +25 offset front and back with 225s in front and 245s in back. Say that!!!!!!!!!
