Compatible engine parts?
Old Aug 23, 2004 | 11:27 PM
RX-Racer's Avatar
Aoohh!!!
Compatible parts
Does the tension Rods/ Dowel pins for a Turbo II 13B motor
fit a FD TT 13B?
Also are the Side Housing (steel housing) for a Turbo II 13B
motor compatible with the FD TT 13B?
Thankz,
JP
Old Aug 24, 2004 | 07:23 PM
RX-Racer's Avatar
Aoohh!!!
Bump!
Old Aug 26, 2004 | 11:31 PM
RX-Racer's Avatar
Aoohh!!!
Help! Please Help!
Old Aug 27, 2004 | 01:36 AM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
yes. all 13B motors use the same tension bolts. good luck
Old Aug 27, 2004 | 12:30 PM
RacerXtreme7's Avatar
NASA geek
YES and NO, the 13bt (Turbo II) side housings will bolt up, but the ports are WAY different from the 13b rew (3rd gen) and you wouldnt be able to use the 13b rew OR the 13bt lower intake. The 13b rew ports are large and enter the side housings at an angle, were as the 13bt ports are smaller and enter the side housings perpendicular.
~Mike..........
Old Aug 27, 2004 | 12:59 PM
Merovingeon
Veteran: Air Force
oops..i didnt read the second part of the question. yea, what racer said, also, the motor mounts are in different places on the FD and Fc motors.
Old Aug 27, 2004 | 01:13 PM
RX-Racer's Avatar
Aoohh!!!
Thankz everyone!
-JP
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
