Engine act's like Blown... only sometimes.
Old Aug 15, 2004 | 08:13 AM
BoOsTin FD's Avatar
Powered by** Rotary
Ok this is kind of stupid question, but if apex seal is bad, can it shake and sound like blown engine only when you start it once, and then whole week it drives like it's perfect?
This happend to me yesterday. I started it and it started shaking, like crazy, vaccum only like 10 or so. So I shut it down, touched stupid MAP sensor and turned it back up and it runs great again.
I'm suspecting Map sensor, but is it possible for it to sometimes work but when it stays over night and then in the cold morning it goes to ****?
Give me your opinions, i'm trying to get a map sensor just in case.
Amel
Old Aug 15, 2004 | 09:11 AM
dgeesaman's Avatar
Maybe there is a leak in the map sensor hose, or the check valve has gone bad.
Still probably the sensor, but have a real good look at all the other stuff before you swap it.
Old Aug 15, 2004 | 09:22 PM
mad_7tist's Avatar
there is no check valve in the map sensor hose. it is a filter. the hose may be leaking also look at the connector. when you replace it reset the ecu also
Old Aug 15, 2004 | 09:40 PM
SWAT81's Avatar
8AN5H33
I get this sometimes as well, but I'm thinking its most likely since I got rid of my emissions and air pump. Therefore there is a glitch that occurs making my idle rough and vacuum below 15. I'm just going to tell you what everyone has always told me, get a PFC
Old Aug 15, 2004 | 10:41 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Amel,
I think it might be the MAP sensor.. Never really heard of one working partially, but I'm sure it's possible. Maybe the connections inside are bad. Come get mine.
Old Aug 16, 2004 | 12:58 AM
BoOsTin FD's Avatar
Powered by** Rotary
I already did
Old Aug 16, 2004 | 07:27 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
So, did it work? Hope so.. I feel bad for even taking your money ya big goof! Thanks for the help too..
Old Aug 16, 2004 | 09:37 AM
BoOsTin FD's Avatar
Powered by** Rotary
I didn't put it in yet. I'll put it in tonight probably, and i'll let you know. Should be fine now i think
Old Aug 16, 2004 | 04:52 PM
RotorJoe's Avatar
Hooray For Boobies!!!
Now if it is your MAP sensor then great, no major problem and a easy fix.
But I have had a something close to that happen in two of my rides and my buddies ride does it more often.
On cold or simi cold starts the car will idle bad and shake. I have noticed vacuum was low on my 3g but can't say for sure on the others (not enough gauges to tell). Sometimes shutting the car down helps and others it just needs to fully warm up and very engine speed for a bit. After a few minutes it all goes away and the idle is normal and rock solid.
I was trippin on this for years. Just a few months ago I thought it could have been a carbon stuck apex seal that frees it's self once warm? This would cause two chambers to lose compression and act like a blown motor. Other then that I have no idea. Both engines have been compression tested and are it great shape. Compression is not an issue although I have never compression checked the engine while this was happening. It happens very few and far inbetween.
Just sounds like what I have run into and wanted to share my experience.
Old Aug 16, 2004 | 05:01 PM
lopedl's Avatar
Forever Modified
Yes, update us with the information as to if it was the map sensor. Also did you do any mods recently, did it just start acting up out of nowhere?
cristoDathird
28
May 30, 2019 08:47 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
rkhanso
Aug 13, 2015 11:40 AM
