Some really good info on the t04z if you havent seen it yet
Old Aug 8, 2004 | 02:59 AM
in case you ever need to compare it to other turbos.
http://www.to4z.com/pdfs/TO4Z.pdf
Old Aug 8, 2004 | 06:01 PM
EricM's Avatar
cool.. thanks, I know some of the specs from hks japan website but not this extensive. Where'd you get it ? HKSUSA ?
Old Aug 8, 2004 | 06:17 PM
no just found it surfing yahoo.. i was pretty impressed myself, thats why i decided to post it, i mean it has a .81 a/r divided housing.. i never seen one of those before.. i think this is a killer turbo.. pricey though..
Old Aug 8, 2004 | 09:47 PM
EricM's Avatar
yeah I know, I thought 0.81 A/R are reserved for undivided only and 0.84 A/R divided.
I guess HKS had these housings made specifically for this turbo.
Old Aug 9, 2004 | 11:13 AM
RETed's Avatar
That looks like an English translation of the T04Z HKS release brochure.
What's interesting is the AX75 graphs.
The AX75 is the big A'PEXi turbo for the FD3S.
The AX75 is NOT an ball-bearing center.
I dunno how A'PEXi managed to get this non-BB turbo to respond so well.
The AX75 uses a Garrett T04 turbine footprint, so it fits a lot of the T04 turbo exhaust manifolds available.
-Ted
Old Aug 9, 2004 | 11:25 AM
EricM's Avatar
AX75F82 is a bit smaller than both the T04Z and T78 though.
If we go by inducer size, it is 64 mm vs 67 mm for T04Z and T78, hence less potential although I'm not so sure how the turbine section of AX compare to the other two.
What's really interesting is the fact that the T04Z outspooled the T04R by 1.8 second in 3-4 gearchange. But when I looked closer, they compared the 0.81 A/R T04R to the 0.61 A/R T04Z. Bastards.... of course the T04Z spools quicker. Nice marketing there HKS.
Old Aug 9, 2004 | 12:13 PM
so would the . 81 a/r divided be too small for a rotary? i know some ppl use the .81 q trim on a t66. or would a rx7 be better off with the 1.00 a/r divided? mainly for street driving.
Thanks
Old Aug 9, 2004 | 02:18 PM
RETed's Avatar
That's true, but the AX75 should compare better to the T04Z.
The AX75 maxes out at around 500hp at the wheels.
The T78 should do better.
Good eyes!
-Ted
Old Aug 10, 2004 | 08:55 PM
vosko's Avatar
Just Call Me Terminator!
well that thing spools FAST on a sr20..........hmmmm ported adapter looks weird
Old Aug 10, 2004 | 09:50 PM
FD3SR1's Avatar
who all sells the to4z? exept hks! something like rx7.com because hks is about a grand higher then retails
Old Aug 10, 2004 | 10:11 PM
FD3SR1's Avatar
so which would you rather have the z or the r? look closely at the info!
Old Aug 11, 2004 | 11:35 AM
racer1's Avatar
flying apex seal
There are two kinds of AX75. The big one the AX75F92 is bigger than the T78 almost the size of the T51R-KAI and the amazing on this turbo is that it's using a new technology called Floating metal instead of ball bearing and believe me it's MUCH faster spooling than the dual ball bearing. Also it is using the abraided technology so it has the best clearance between the fan and the housing which makes ii one of the most efficient turbo ever been made.
Old Aug 11, 2004 | 05:51 PM
EricM's Avatar
If so then all the race teams in the world would discard ball bearing turbos for these new wonderful floating metal bullshit right ?
Please back up your claims with some accurate data...
Old Aug 11, 2004 | 06:25 PM
racer1's Avatar
flying apex seal
As i said it's a new technology, expensive turbo, and you won't find it in many cars. Actually the only car i've seen it, is the Apexi Drift Car and it's not the AX75F92 it's the smaller one.
I'll be able to back it up and post some dyno graphs as soon as i get it installed on my car
Old Aug 12, 2004 | 02:42 AM
artowar's Avatar
FD3SW211E55
"Floating metal" eh? To me that name suggests a plain bearing (i.e., the metal floats on a layer of oil), unless they've come up with a way to run a magnetic bearing in a turbo
Do you have any links to a description of the this new bearing technology? I ran Apexi's website through babblefish and the translation only seems to suggest closer impeller tolerances, perhaps via an abradable seal.
Old Aug 12, 2004 | 11:33 AM
EricM's Avatar
I agree with artowar, I think floating metal is just plain bearing technology.
racer1, please do that. Also, where do you get the kit from ? Direct from Japan ? How much is it ? Please post pics before and after.
Old Aug 12, 2004 | 11:58 AM
racer1's Avatar
flying apex seal
Actually i am buying the kit direct from Apexi Japan and what i've posted is what they've told me on our phone conversation before placing the order. It will cost around $5000.
Old Aug 12, 2004 | 04:18 PM
Garrett's Avatar
Interesting marketing by APEXI. They sold you on standard journal bearings by calliing them "floating metal" technology. Unless you can back up your claim with an article or something we would have to presume your car is also powered by unabotanium alternative fuel. Which I heard is the heat on Cyprus.
Old Aug 13, 2004 | 01:27 AM
artowar's Avatar
FD3SW211E55
I agree with artowar, I think floating metal is just plain bearing technology...
I don't really have an opinion on what it is. I'm just speculating based on the phrase Apexi's used with racer1.
Apexi seems to like to develop their own products, so perhaps they've actually come up with something new that does work better than ball bearings. That would be good news.
Old Aug 17, 2004 | 07:38 PM
back to the t04z. would you guys think the t04z .81 a/r divided exhaust housing would be good on a stock/mild streetport? or it would be too small?
thank you
cristoDathird
28
May 30, 2019 08:47 PM
