Faq For Idle Problems
Old Mar 25, 2004 | 10:58 AM
wozzoom's Avatar
FAQ FOR IDLE PROBLEMS (Rough Idle, Idle Pulsing)
INTRODUCTION: I was having some “Rough idle” problems on my 89 GTUs and I thought I would share my experiences of how I resolved them. I’m writing this as a FAQ of what to do when ALL ELSE FAILS! You may want to check some other “simpler” things (like the TPS) before you follow the steps below. Feel free to add any other advice you may have on this topic. Note: This FAQ is written assuming you are using the stock ECU and all emissions equipment is intact.
1)Vacuum leaks, vacuum leaks, vacuum leaks… You will never be able to set a rock solid idle if there are any vacuum leaks. Cracked vacuum lines, old gaskets, bad o-rings/grommets around the injectors are all suspect. The only way to fix all the vacuum leaks and eliminate all doubt is to tear everything down to the bare block. Clean off all old gasket materials and replace with new gaskets and new vac lines. It’s also a GOOD IDEA to apply a light coating of silicone to both sides of every gasket.
*TIP* My favorite way to remove old gasket materials is 3M Gasket Removal Pads. (See: http://products3.3m.com/catalog/us/e...er/output_html )
OFTEN OVERLOOKED #1: The large rubber hoses from the BAC and AWS valve. These hoses become loose over time and often need hose clamps to make a good seal after they’ve been removed a couple times. Especially where they attach to the intake snorkel.
OFTEN OVERLOOKED #2: The throttle body spacer. Remove it and put a small amount of silicone gasket maker on both sides. Be careful not to block any of the vacuum passages on the spacer.
OFTEN OVERLOOKED #3: the ACV gasket and check valve. This gasket doesn’t come in any of the engine rebuild kits and can often be hard to find at the dealer. Don’t overlook this gasket as a vac leak source. Especially when using an ACV block off plate.
OFTEN OVERLOOKED #4: The brake booster vacuum lines. Especially the one directly above the exhaust manifold/turbo.
2)Resistance Values – Operational Checks. While everything is apart, spend the 15 minutes to verify operation of all of the sensors and solenoids. For the operational checks, apply 12V and listen for “clicking”
- BAC: Resistance: 10.7-12.3 kOhm. Operation: Apply 12V to check
- AWS Solenoid Resistance: 9.3-11.3 kOhm. Operation: Apply 12V to check
- Air Intake Temp Sensor (In Manifold): @ 77 Degress, 33 +/- 4KOhms.
- Water Thermo Sensor Resistance: @ 68 Degrees, 2.5 +/- .2KOhms
- All Vac Solenoids (Operational Check): Apply 12V to check, listen for click. It’s always wise to blow through the solenoid during this test to check for leakage.
- ACV (Operational Check x2 plugs): Apply 12V to check, listen for clicks.
- TPS: Attach an Ohm meter and check for flat spots.
3)Injectors – If your injectors have never been cleaned, do it now. My favorite place to send them is Marren Fuel Injection. http://www.injector.com/ Cost for 4 injectors is around $100 bucks and worth every penny. They will replace the caps and o-rings, however you will need to purchase the upper and lower injector grommets. *TIP1* Apply a thin coat of oil to the injector grommets/o-rings before installing them so they don’t tear. *TIP2* Check the pulsation dampener for leaks (loose screw) and the fuel lines for cracks.
4)Throttle Body – Clean the throttle body and get all of the carbon build up off the primary and secondary plates. Verify the clearances of the primary and secondary throttle plates. (See Workshop manual – Fuel and Emissions Control) This step is VERY IMPORTANT! Get the clearance of the primary throttle plate perfect. The clearance between the throttle plate and the bore should be between .02” and .03” inches. (for all 5-speeds) *TIP* If you don’t have proper feeler gauges to take this measurement, use dial calipers to find a piece of wire that is the proper thickness.
5)Reassemble – Put everything back together. Pay special attention to the connections between the lower intake and the intermediate intake. Tighten all bolts evenly.
6)At this point: You have eliminated all sources of vacuum leaks, verified all electronic controls, and adjusted the throttle body. You are now ready to start the car and let it warm up.
7)TPS. Once the car is fully warmed up, turn it off and check the TPS. PERSONALLY I prefer the LED Test lamp method to check the TPS. Others prefer the Ohm meter method. The use the LED test lamp method, you need Two 12V LED’s from Radio Shack. http://www.radioshack.com/product.as...5Fid=276%2D271
Tie the Positive (red) wires together and attach a ¼” spade connector. Attach a ¼” spade connector to each of the LED Ground wires. Find the Green test plug next to the Pressure Sensor. (It has 3 wires) Insert the Positive spade connector into the top of the plug and the two grounds side-by-side into the bottom of the plug. Adjust the TPS screw on the throttle body until only 1 of the LED’s is lit. Only adjust the TPS when the car is 100% warmed up!!!.
8)Ground the “initial set” connector. This is the single green plug located next to the battery. Adjust the idle speed screw located on the top of the throttle body until the idle is at 750 RPM +/- 50 RPM.
9)Test drive - Repeat step 7 and 8 if the idle still pulses.
10)At this point, if you’ve done EVERYTHING correctly, your idle SHOULD be rock solid. If the idle still pulses, (IE: Fluctuates between 750-1500 RPM) you’ll need to recheck for vacuum leaks and ensure the throttle body plates are set right. Also check your engine grounds and fuel pump pressure. Check the alternator for proper voltage (Above 14V with the engine running) and finally check your ignition system.
Old Mar 25, 2004 | 11:28 AM
*a*jones*'s Avatar
your a hero! i need to start on this tonight...this has to be archive bound!
Old Mar 25, 2004 | 11:29 AM
Visago's Avatar
this outta be a sticky
Old Mar 25, 2004 | 12:03 PM
OH!!! where were you like three weeks ago when i was looking for help with my idle???
great writeup.
1 vote for sticky.
Old Mar 25, 2004 | 03:23 PM
Verbal's Avatar
i like rotors
How did i miss this
Very good info-
Old Mar 25, 2004 | 09:42 PM
wozzoom's Avatar
Ok, I've seen a couple votes for sticky material...
Can anyone think of something that I missed?
Old Mar 25, 2004 | 11:39 PM
DerangedHermit's Avatar
sticky >>
Old Mar 26, 2004 | 08:41 AM
hugues's Avatar
Why am I here ?
thanks wozzoom for a nice write-up ...
here's my take on idle issues (for what it is worth):
http://www.geocities.com/huguesdc1/faqidle.html
Hugues
Old Mar 26, 2004 | 10:10 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
bump for the team. Sticky or archive please.
Old Mar 27, 2004 | 01:40 AM
Wankels-Revenge's Avatar
Defected to the dark side
bumpity!!
Ya this is a great write up...its definetly gonna help when im fixing my idle in a few weeks. Thanks for the info
STICKY THIS THREAD!!!
or archive it at least
Old Mar 27, 2004 | 11:18 AM
totallimmortal's Avatar
Is that thing Turbo?
very good write up, one more thing probably not needed for everyone but, anyone with a safc I've found that richening the mix at idle made my idle rock solid at around 800 rpm, this was of course after adjusting the tps and replacing some old vac hoses, but the richness sure helps alot
Old Mar 29, 2004 | 02:06 PM
wozzoom's Avatar
If you had to add fuel with the AFC to get the idle rock solid, then you have an vacuum leak.
I also have an AFC in my GTUs. Before my repairs, I had to go plus +5 on the AFC to get the engine to idle anywhere near 800. (It still had a miss to it) After my repairs, I am now able to go to minus -15 and still have it idle rock solid at 750 RPM.
Old Mar 29, 2004 | 02:39 PM
J-Rat's Avatar
Alcohol Fueled!
http://www.teamfc3s.org/info/articles/idle.html
Old Mar 29, 2004 | 02:45 PM
Batguano's Avatar
Well done. Now, I can rest in peace.
Old Mar 29, 2004 | 02:50 PM
wozzoom's Avatar
Good link!
I like the detailed description of the Idle Control components.
Would it be prudent to copy and paste that information into this thread? Of course we would have to give the original author credit! I think it would great to have all this idle information compiled into one thread.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
rx7shirley
Sep 2, 2015 02:11 PM
