Rx8 rotors in N/A FC Update
Old Aug 3, 2004 | 04:30 PM
ViperDude152's Avatar
Rotary Power Information
Aight guys.
In August i posted a thread from the email i got from mazdatrix about using the rx8 rotors in the FC N/A engine.
Here is the email for August
We are using RX-8 rotors in one of our SCCA E/Production "street port" 86-91 13B non-turbo engines.
We do no mods to the rotors (except installing the racing rotor bearing). We are using RX-8 racing ceramic apex seals (the OEM RX-8 steel seals warped too much having to cross the exhaust port). (There IS enough metal to cut the apex seal groove for either 86-91 2mm seals or earlier 3mm seals -- we are looking into making that service available, but are not ready yet) The rotors are run "backwards" (front in rear, rear in front) so the angle cut on the side of the rotor gives more intake opening timing (RX-8 uses the cuts for the side exhaust ports). Do not use the "oil scraper ring" outside the second oil control ring. DO NOT use RX-8 corner seals -- they DESTROY 86-91 side housings !!!! (use 86-91 corner seals, TRUST ME).
They ARE lighter than 89-91 non-turbo rotors, have higher compression, and are less expensive.
With all of the above said: We have YET to attain even the SAME horsepower on the dyno as we are getting from our race engine(s) using the 89-91 non-turbo rotors !!!
Potentials: With the RX-8 rotor having the side seal further outboard, we were able to increase the (ported) intake opening timing versus the earlier rotors -- it may be too much ??? (does not seem likely)
Running the rotors with the angle cut for intake opening may also be in the above category.
We always set pre-92 side seal clearance at about .0015 (1 1/2 thou). The SMALLEST clearance we could get, using the LONGEST of the available "pre-sized" RX-8 side seals was about .010 (10 thou), with the worst on this set of rotors of about .016 (16 thou). This gives a much lower "sealing" than we like.
Other than the above, at this time we are not at all sure why the power is less than when using the earlier rotors.
No, we have not done the REAL test -- run the SAME engine on the dyno, and only swap the rotors (backwards, then normal). That equals three builds, and three full dyno on-and-offs + dyno sessions.
Dave Lemon,
Owner of Mazdatrix,
The dyno operator and driver of the E/P car
Here is the update they just sent me yesterday
I have an "update" since that original response ----- We took the "RX8 Rotor" engine apart (having MASSIVELY over-revved it when the trans broke in practice -- probably hit 14-15k at least, AND did it 3 times. Broke a few tension bolts, cracked gears, spun a bearing, etc.but still ran the whole Thunderhill Double National weekend!!). We ran it on the Dyno (dyno had been up-graded to full computerized) before taking it apart (did not know how much damage had been done). Rebuilt it, AND changed the porting some, AND used 89-91 rotors, ---- AND got about the "same" low power !!! REALLY puts a question mark back on/about the RX8 rotors. So --- WE still have not seen any MORE power from them, but WE are seeing (WITH the porting we had been using) "about" the same power ??????
Obviously, more testing needs to be done.
Dave Lemon ---
there ya go guys... Hopfully they will figure out why they are not getting more power soon enough..
Justin
Old Aug 3, 2004 | 06:29 PM
b005td7's Avatar
in other section, i beleve is rotary performance there was a guy using rx-8 rotory in n/a form he manage to squeeze around 230-250 hp there
also in ausrotary.com theres a few threads about it as well
me myself still could not stop thinking about idea of rx-8 rotor into my turbo vert ....
all i need is tuning ....
well money too
Old Aug 3, 2004 | 06:32 PM
badfish229's Avatar
Kutabare
This is interesting. I don't understand the point of using the RX-8's high-compression rotors. Wouldn't the higher compression lead to using a higher octane fuel?
Old Aug 3, 2004 | 06:41 PM
j200pruf's Avatar
RIP Icemark
The only thing that I could think of that would make the rx8 rotors not as powerful as the stock rotors would be the slight chamfering(sp) on the edges of the rotor faces that are suppose to help with timing on some of the side ports on the Reni motor. The following pic can be found at http://www.mazdatrix.com
RX8 rotors
But I don't see how that would make a big difference because I know quite a few engine builders do this to their race rotor to save weight. Like this picture I found at http://www.pineappleracing.com/
Lightend RX7 rotor
Old Aug 27, 2005 | 03:16 AM
TurboIIGuy's Avatar
Driveline Killer
wow.....There is so much I need to research.
Has anyone seen any posts of P-Port motors with RX8 rotors??
I had previously thought, due to others telling me, that RX8 rotors were not compatible with other blocks.
But i thought if they were that they would be great for a P-port due to the higher compression.
But after hearing that the power levels between the 2 sets of rotors are not very substantial I am confused and determined to figure out why...
Old Aug 27, 2005 | 04:30 AM
iceblue's Avatar
Passing life by
The beveling allows a longer intake port duration. Yes the rotor gods that have been doing this for years do this to there motors and CRC has some of the craziest beveling I have ever imagined. The RX8 bevel is very very small but still makes a noticeable difference.
TurboIIGuy - 13b rotors are 13b rotors for the most part. Yes the RX8 rotors can be used with a few short upgrades.
badfish229 - Why would you think that? The 8 is only 10:1 compression barely 1 point over the 89 to 91 NA motors. Yes if you keep going up then higher octane is needed but if this was the case here do you think RX-8s need to run on C1 race gas or something? It has been engineered from Mazdaa that 10:1 is the highest compression the current rotary design can see before a loss of HP is starting to be obtained due to the elongated combustion chamber.
Old Aug 27, 2005 | 09:45 AM
felixwankel88's Avatar
hummmmmmmmmmm, i would think the rx8 ones should produce more power,
Old Aug 27, 2005 | 12:16 PM
ddub's Avatar
i am legendary
I think you mean CLR, not CRC.
If you read the email from Mazdatrix, they don't do any modification to the rotors apparently. But I've also heard differently from others.
I don't know where you're getting "barely 1 point over" from... but 89-91 N/A rotors are 9.7:1 and RX8 is 10:1, that's 0.3 higher.
It's not just about compression, it's about tuning too. Mazda paid a lot of attention to the timing of the rx8, a LOT.
Old Aug 27, 2005 | 12:17 PM
ddub's Avatar
i am legendary
Higher compression doesn't always mean more power, you have to pay attention to a lot more factors than that.
Old Aug 27, 2005 | 01:54 PM
iceblue's Avatar
Passing life by
Yes as dDub said there is alot of factors then just compression that matter there.
On the compression that I was getting at dDub is that the differance I dont know the correct wording to use here but that they are very little like not even a total point, minute I guess.
Yes CLR thank you!
Old Aug 28, 2005 | 11:41 AM
riceburner1r2001's Avatar
man if lemon only knew what he was talking about . i will have them in my all motor drag car soon i just got the seals in.. too bad he never could get his 1st gen back up again
Old Aug 28, 2005 | 01:53 PM
IaMtHeRuThLeSs1's Avatar
I'm awesome!
I wouldn't think that just b/c you used 8 rotors you'd net more power
from what i understand its the way the intake and exhaust ports that give the 8 its power.
Old Aug 28, 2005 | 05:32 PM
RETed's Avatar
Two stage intake manifold + a *higher* redline allows for a higher power ratings.
The exhaust actually drops the power potential, and it was designed for better emissions.
-Ted
ZacMan
Sep 19, 2015 09:20 PM
mulcryant
Sep 9, 2015 05:24 PM
Ian_D
Sep 6, 2015 10:38 PM
