86 chassis in atlanta, come pick it up.
posting in here because i think you guys would be most intersted in it.
its an 86 FC chassis. i have completely stripped it down. it started out as a project track car but ive been too busy with other stuff to play with it. i figure ill let someone else have at it.
when i got the car it came with a 88TII swap, but it was not wired properly. i have all the turbo components and the motor is supposed to be good, but i have never seen it run.
i bagged and tagged all the bolts i took out of the car, so it should be fairly easy to get back together. the interior is not included, it was mostly trashed so i tossed it.
i took the sunroof out and cut the mount brackets out, removed the rear speaker pods, have most of the tar out of the chassis. its been lightened up a good bit.
the car and all of its parts are free to whoever wants to pick them up. i live up by the mall of ga (near atlanta). if you cant pick it up i will deliver it to your door for $50+ $1/mile from my house. the car does not roll, you will need a trailer.
email me if you want it, russ@speedjunkie.net. i dont check the boards too often so first email gets it...
I'm in Roswell.
What all is included?
