Sponsored by: CARiD
Does anyone make a dual needle water temperature gauge?
Old Jul 30, 2004 | 09:00 PM
Syonyk's Avatar
I've searched for a while and can't seem to find anything.
I'm looking to put water temperature probes in two spots on my S4 - one in the thermostat housing coming out of the engine block, and one at the outlet from the radiator. I'd prefer to not have two gauges. A double needle gauge would be perfect - one needle for the block coolant, one for the radiator coolant.
Does anyone have an idea of where I could find this, or if it's even worth it? I'm working on building my car up for autocross/track/hard highway runs, so coolant temperature information is fairly important to me.
-=Russ=-
Old Aug 4, 2004 | 12:20 PM
88GT's Avatar
huh!
Old Aug 4, 2004 | 12:48 PM
Carl Byck's Avatar
Mad Man
If you take a reading at the thermostat that is the hotest the coolant will be, if you are O'k there, you are O'k everywhere else. If you are wondering what the post radiator temp is, weld a bung on, and move your sensor temporarily. IMHO there is no reason to constantly monitor both. Carl
Old Aug 4, 2004 | 01:21 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
http://www.racerpartswholesale.com/spagauge2.htm dual digital gauge 230 bucks
OR... you COULD get one gauge and install two sending units, make the grounds common and put a switch on the input leads to switch the gauge between either sending unit.
Old Aug 5, 2004 | 05:07 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
there's a good idea!!
streetlegal?
Mar 17, 2022 02:46 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
