All coolant hose part numbers
Old Jul 26, 2004 | 12:11 PM
DamonB's Avatar
The FD's are getting old and the rubber coolant hoses are often overlooked. As high as the underhood temps of these cars are all hoses should be replaced.
Here are all the Mazda part numbers for every coolant hose:
radiator hoses:
N3A1-15-185A lower radiator hose
N3A1-15-186 upper radiator hose
turbo coolant hoses:
N3A1-13-536 turbo coolant hose #1
N3A1-13-54X turbo coolant hose #2
AST hoses:
N3A1-15-380C AST to overflow bottle
N3A1-15-184A AST to radiator
N3A1-15-183 AST to coolant neck
throttle body hoses:
N3A1-13-681A upper throttle body
N3A1-13-691B lower throttle body
N3a1-13-692A water pump housing to hard line (behind alternator)
heater hoses:
FD01-61-213B block to firewall hard line (driver side)
FD01-61-212A heater core at firewall
FD01-61-214A water pump housing to hardline (passenger side)
FD01-61-211A hardline to heater core (passenger side)
Old Jul 26, 2004 | 01:44 PM
TainoIndian's Avatar
i am looking to buy these
thanks for the info, my only question is how much will these all cost?
I am short on funds now, and dont want to call store and waste thier time looking up parts if i cant afford. also who did buy them from
thanks
Old Jul 26, 2004 | 01:48 PM
spurvo's Avatar
don't race, don't need to
If you go to Mazdatrix.com, you can price the list on these. Then reduce it by about 15-20% if you call Ray at Malloy.
Damon, thanks for giving out that info!
Old Jul 26, 2004 | 02:09 PM
great
thanks i am on my way to mazdatrix
after checking it out i can definantly afford this now. i thought it would be like $50.00 per hose or something.-----> on my way to malloy
Old Jul 26, 2004 | 02:30 PM
Jay7 Nyc's Avatar
call 1 888 533 3400 Ray at Malloy Mazda he should give good prices..
Old Sep 2, 2004 | 11:47 AM
BLKTOPTRVL's Avatar
So far I have paid:
$18 for the upper turbo hose
$28 for the heater hard line to the pump housing
$11 for the lower turbo hose
$07 for the lower UIM hose
BTW, the lower turbo hose is a PITA to get to. It is very hard to get the lower turbo hose clamp off; especially when the engine assembler left the tangs of the clamp at a 05:35 attitude.
Has anyone replaced the spring clamp with a screw type?
Old Sep 2, 2004 | 12:07 PM
R. Gambino's Avatar
Malloy Mazda has a special...all underhood hoses $140.00
Old Sep 2, 2004 | 12:14 PM
RotorJoe's Avatar
Hooray For Boobies!!!
You are the man and read my mind.
Thanks, very helpful.
Old Sep 2, 2004 | 12:39 PM
turbojeff's Avatar
Do it right, do it once
Check the Ray Crowe/Malloy Mazda thread on coolant hoses right now. IIRC he is selling all 14 for $140, which if you do the math averages out to $10/ea.
Old Jun 2, 2005 | 10:59 PM
scotty305's Avatar
~17 MPG
Bump for summer weather quickly approaching.
-s-
Old Jun 3, 2005 | 12:16 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
I'm down for another group buy on coolant hoses from Ray.
Old Jun 3, 2005 | 01:23 AM
technonovice's Avatar
Jinx
If you call Malloy and tell them you want all the hoses then you will not need to recite all those part numbers.
Old Jun 3, 2005 | 05:43 AM
dgeesaman's Avatar
What's scary is when Ray starts reciting them from memory
Old Jun 3, 2005 | 06:48 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
thanks Damon.
i remember driving my 80,000 mile 1st gen on the expressway and smelling just a whiff of coolant. i immediately switched off the ignition. it was a rupture in the driver's side coolant line from the heater/firewall to the block just below the oil filter.
the engine vibrates, the firewall connection doesn't...... creating lots of challenges for that specific hose.
the two coolant hoses absorbing all these vibrations are the driver's side firewall to just below the oil filter and the front coolant hose from the hardpipe ( runs alongside the motor )to the front of the motor on the passenger side.
mix in our underhood temperatures and the fact that the rotary is prone to immediate failure from coolant loss, unlike a piston engine, and you should have significant motivation to call Ray.
either buy some new coolant hoses or a motor.
howard coleman
Old Jun 3, 2005 | 12:16 PM
DamonB's Avatar
Sage advice. Not too long after buying my FD I ruptured a turbo coolant hose. What made me mad was that I swore for a few days previous I could smell whisps of coolant after shutting the car down but could locate no leaks and was losing no coolant. Once the hose ruptured t was obvious and I was lucky to be close to home.
Back then I didn't know where all the hoses were. Starting over again I would have replaced them all the first week or two I had the car.
Old Jun 3, 2005 | 02:27 PM
The 14 hoses for $140 is about as low as he can go, prolly right above cost.
Old Jun 3, 2005 | 09:52 PM
Jinx
For me its worth replacing them all at the same time. That way I know exactly how old every one is.
Old Oct 3, 2005 | 01:45 PM
NINjaX7's Avatar
S S S SOLD!!! **(
dangit, i just bought 7 of the water hoses from mazdatrix for 114, i should've done the whole kit, boy do i regret that
Old Oct 3, 2005 | 01:49 PM
alberto_mg's Avatar
FWIW, Malloy's price is now around $160 for the set.
Old May 12, 2006 | 02:10 PM
RX7 allnight's Avatar
707
Originally Posted by BLKTOPTRVL
So far I have paid:
yes, the 2nd turbo hose is a PITA!! i have screw type on both, they came loose after 70,000 so it is something to be retightend every 50k i would assume. they were leaking on the turbos.. just enough to loose coolant but never see any on the ground, i hope this solves my over flow problem.
Old Oct 8, 2007 | 11:28 AM
taz8924pr's Avatar
taz8924pr
Somebarry know the part numbers for coolant hoses for FC?
Old Mar 1, 2009 | 02:10 PM
1QWIK7's Avatar
White chicks > *
Does anyone know what type exactly these rubber coolant hoses are made of?
Cause i think it would be cheaper and make more sense in the longrun to go to like an autozone and getting a roll and just cutting to your desired length.
Also have any of you used silicone hose instead of rubber hose for coolant?
SARD sells a roll for coolant, wondering if thats any good.
Old Mar 1, 2009 | 03:45 PM
Mahjik's Avatar
Mr. Links
The main issue is that the OEM hoses are pre-formed. You can use standard "heater hose" from NAPA or Autozone, but you'll end up getting kinks in the lines to make the required bends. You can also get pre-formed heater hoses made for other cars and cut them up for your own use. However, that will end up being just as expensive and more time consuming than just getting the OEM hoses.
Old Mar 1, 2009 | 04:25 PM
Juan's Avatar
Im a tall midget.
Just a wild guess here but maybe someone in the FC section?
Look through the FAQ and stickies in there. I remember there being a parts diagram in there somewhere so you can get your own part numbers if needed.
Old Mar 2, 2009 | 04:07 PM
NoPis10's Avatar
Committee Member #2
There is a thread about how silicone hoses have a high water permeation rate and cause loss of water in your cooling system..
L8R
