Preferred porting??
Old Jul 19, 2004 | 08:35 PM
RedBaron7's Avatar
It's smog legal
Question Preferred porting??
Does anybody have a Bridge port, running a T-78?? What port would you perfer for max HP on a T-78? Everybody talks about street ports, but no bridge ports, wouldn't that be more fuel/air = more HP over a aggressive street port???
Old Jul 19, 2004 | 08:39 PM
1revn3rdgen's Avatar
I think with a turbo that big you should be able to get away with a bridge.
Old Jul 19, 2004 | 08:44 PM
RedBaron7's Avatar
It's smog legal
I'm rebuilding my 13B, thinking of doing a bridge port, wanted to see if anybody has done it, or any opinions about it???
Old Jul 19, 2004 | 08:52 PM
vel525's Avatar
Woo Hoo, It Runs!!
doesn't jason have a bridgeported motor with a t-78?
Old Jul 19, 2004 | 09:01 PM
coldy13's Avatar
Yeah, shutup kid.
I thought jason's was just a very large streetport?
Old Jul 19, 2004 | 09:04 PM
RedBaron7's Avatar
It's smog legal
He(Jason, RX7store.net) said he has a agressive street port.....does anybody have a T-78 with bridge port, and what are the pro's and con's???
Old Jul 20, 2004 | 03:02 AM
Sice your in so cal just try to give xs engineering(714)698-8300 a call they build and tune rotaries ask them what they think.
Old Jul 20, 2004 | 03:10 AM
HeX's Avatar
HeX
01010010011010110
They do good work.
Old Jul 20, 2004 | 11:13 AM
sillbeer's Avatar
Pro's, You get more HP out of your engine. Con's, You reduce the live and driveability of the car. I know guys that have "driven" bridgeport fd's in he past as daily drivers, but I wouldn't consider them practicle. I say driven instead of drive because both of the fd's i'm thinking of have had different motor's put in since the original bridgeported motors.
-Destin
Old Jul 20, 2004 | 12:12 PM
RedBaron7's Avatar
It's smog legal
Ya, I my FD is not a daily driver I have a RX-8 for daily driver. Just looking for the best port for my T-78.......
-Ryan
Old Jul 20, 2004 | 12:37 PM
RedBaron7's Avatar
It's smog legal
Thanks for the info, I know who they are. They are expensive, but may be worth it.
-Ryan
Old Jul 20, 2004 | 02:39 PM
go with a large streetport..... then, you wont have to change blocks every 10k miles!
Old Jul 20, 2004 | 06:09 PM
RedBaron7's Avatar
It's smog legal
That's what I decided on going with. Anybody have a rear housings for sale(4 port)??
Old Jul 21, 2004 | 12:00 AM
jantore's Avatar
I would recomend u go for a "Torque port". It's street port that is ported for Torque. I have tried both and Torque is the best. U get more low end power, compeard to a laaarge streetport that will give u more top end power.
I like to have it all over the rpm range, and not just on the top.
JT
Old Jul 21, 2004 | 12:04 AM
Pressurized's Avatar
i have a bridgeport with a T51...i would go with the large streetport if i were you, more streetability, and much easier to tune....we are still having problems getting mine to run smoothly.
Old Jul 21, 2004 | 12:25 AM
razorback's Avatar
You've Been Punk'd
what does a "torque port" look like?
Old Jul 21, 2004 | 07:36 AM
jantore's Avatar
Well im not sure, but u should ask the guy that ported my engine
Old Jul 21, 2004 | 09:39 PM
rotting in the garage's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7912199105
Old Jul 21, 2004 | 10:45 PM
SnowmanSteiner's Avatar
Ga-nome liberator
Changing housings every 10k miles is quite an understatement. Bridgeporting doesn't reduce the life of your engine that significantly unless you are just beating the hell out of it, which has no relation to the port. Yes they will wear out quicker. I would consider going with a 1/2 bridge. The port one of the plates on each rotor, so that you maintain greater driveability and also gain a significant advantage over a streetport. It will spool the T-78 a lot quicker than a streetport, and won't limit you in the top end.
- Steiner
Old Jul 25, 2004 | 07:48 PM
badfish229's Avatar
Kutabare
I agree. The only difference, I believe, between an aggressive street port and a bridge port is the flow area. In terms of driveability, an aggessive street port could be just as driveable as a bridge port. There are other ways besides porting that can help spool your T-78.
Old Jul 26, 2004 | 08:33 PM
RedBaron7's Avatar
It's smog legal
thanks for all the info!!!!
-Ryan
mulcryant
Sep 9, 2015 05:24 PM
doritoloco
Sep 5, 2015 12:41 PM
