cranking compression on a ported motor
Old Jul 14, 2004 | 09:06 PM
black93RX7's Avatar
20BFD
Here's what's up:
6000 km on new street ported motor w/ 3mm seals, new rotor housings and dowell pinned
Poor mans compression tester read 60psi in each rotor on a warm engine consistently
However gas pedal was not pressed when this was done, if this makes any difference.
Is cranking compression less than compression under load for this type of motor since the apex seals are not being forced against the housings?
Old Jul 14, 2004 | 10:18 PM
Xcessive's Avatar
Are they 1 piece seals? I had my last motor with 3mm 1piece ceramic
seals and when it got hot the compression was about 70-75 psi. It was hard to start is yors hard to start also? Ralph
Old Jul 15, 2004 | 12:03 AM
black93RX7's Avatar
20BFD
Yeah mine is hard to start most of the time, especially when its hot. I am not sure if they are 1 piece seals or not, I will ask tommorrow.
I am putting it on the dyno in the morning, I'll see what king of numbers its putting down.
What happened to your last motor?
Erik
Old Jul 15, 2004 | 04:33 AM
t-von's Avatar
Rotor Head Extreme
Re: cranking compression on a ported motor
It does make a differance. Flooring the gas opens the butterflys to allow more air to enter the engine. Try retesting to show what the true numbers are.
Old Jul 15, 2004 | 05:03 AM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
yea, what T-von said. without the throttle open, its limiting the amount of air that goes into the motor. less air=less compression
Old Jul 15, 2004 | 07:21 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
wide open throttle plates allow the starter to crank the motor over at a higher rpm. your compression #s are quite variable relating to rpm. check out the graph of cranking rpm and compression readings in the shop manual.
howard coleman
Old Jul 15, 2004 | 02:47 PM
black93RX7's Avatar
20BFD
I just had the car onthe dyno, I am dissappointd with the results. Check out my post in the single turbo section under (t-78 dyno w/ ported motor).
I am going to compression test the motor again today with the throttle open.
Thanks for the feedback
Skeese
65
Mar 28, 2017 03:30 PM
PhillyFC
Aug 21, 2015 06:36 PM
elfking
Aug 19, 2015 09:48 PM
86glxNA
Aug 18, 2015 03:33 PM
