Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Stock ECU map
Old Jul 10, 2004 | 11:31 AM
EProdRx7's Avatar
Stock ECU map
Just wondering if anyone here has mapped a stock S4/S5 ecu for use as a base map on a stand alone system?
Old Jul 11, 2004 | 11:36 PM
Evil Aviator's Avatar
Rotorhead
You can't really do that because standalone EMS's don't have the same inputs, outputs, or processing features as the stock ECU. For example, nearly every standalone EMS uses a speed-density primary metering system, while the stock ECU uses a mass airflow primary metering system.
Digital Tuning, Inc., has researched the original ECU codes, and produced a modified chip:
http://www.pocketlogger.com/index.php?pid=rtek7feat
Old Jul 12, 2004 | 12:07 AM
EProdRx7's Avatar
I was thinking more along the lines of injector pulse vs RPM and the same for ignition curve. Would be kind of interesting to map those and then plot them against manifold pressures and throttle position sensors of the standalone system I intend to use.
incubuseva
14
Sep 3, 2015 12:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
