ideas for getting air to radiator?
Old Nov 13, 2001 | 10:16 PM
94touring's Avatar
I have a fmic with the fluidyne radiator, and would like to get more air to the radiator. I have been trying to formulate a plan to direct more air to the radiator with a scoop or some sort of a duct, but haven't had too much success. Anyone else have any ideas to direct more air toward the radiator? I use my haltech to keep the fans on all the time and that works great, but its when I keep it in high rpms for long periods of time that the temps start to get a little too high for me.
Old Nov 13, 2001 | 10:50 PM
atihun's Avatar
I have been considering installing the radiator horizontally and creating a custom scoop underneath in the undertray.
Old Nov 13, 2001 | 11:18 PM
0piston's Avatar
Re: ideas for getting air to radiator?
Did you try some sheets of aluminum yet, works good....bend/fit them from the left and the right frontnose opening. This way it funnels air in, instead of escaping around it and there is an improvement in cooling temp when doing this. I have also decided that I am going to keep my aircon, so another thing i am currently working on is droping the angle of my aircon sh/t(that blocks the radiator) several inches from the top with some fabricated brackets I'm making. People in Japan have noticed a 5-10 C' in improvement doing this. Remember a little bit goes along way in dealing with the rotary cooling system.
Old Nov 14, 2001 | 06:19 AM
hapa's Avatar
94touring- I'd try adding those aluminum side pieces, and also sealing all areas around the radiator. Basically just make sure that ANY air that goes through the front center section of your front end flows through the radiator. Kevin Wyum way back in the day, just taped off all the sides of his radiator, and he noticed such an improvement he didn't even upgrade his radiator.
eric
Old Nov 14, 2001 | 07:51 AM
cewrx7r1's Avatar
Eye In The Sky
I have a Blitz FMIC with the M2 large radiator and AC still intact and working. Need it here in Houston. My temps are only about 3-5 higher while driving slowly with the fans off. High speeds on the road the temps are fine. I use the fans only for stop and go and when racing.
Remove the two plastic inserts on both sides of the radiator inlet.
Then make aluminum blocking plates for the sides. Plug up any openings around the radiator with large pieces of foam rubber glued in. Do the same for any place air can leak past the IC but not go through the radiator.
Old Nov 14, 2001 | 10:27 AM
94touring's Avatar
Thanks for the replies, I will try the sheets of aluminum this weekend. I have already moved the radiator horizontal, so that should help some too.
Microtech
30
Apr 23, 2016 06:37 PM
