Haltech Haltech Info
Old Nov 12, 2001 | 10:33 PM
benny's Avatar
Haltech Info
I put a complete story about my Halteck E6K on my 13B turbo race car.
I just finish a new peripheral port with 2 55mm throttle bodies.
I should go to dyno next weekend to map my ecu. I will let you know how much HP I've got.
Thx
Benny
Old Nov 13, 2001 | 11:59 AM
Styk33's Avatar
Haltech E6K
Arrow
That is very little throttle body. Factory for a 13B-REW is 145mm. Two 50mm secondaries and one 45mm primary.
Best of luck to you.
Old Nov 13, 2001 | 10:05 PM
benny's Avatar
No it's big
55 mm bore sizes is pretty big.
Here are some info
http://twminduction.com/ThrottleBody...leBody-FR.html
look at the 3000 series.
Thx
Benny
Old Nov 14, 2001 | 09:23 AM
tims's Avatar
this is also a peripheral port motor and not turbocharged. each rotor has a 55mm throttle body. this is very large as most people use a 48 or 51mm IDA Weber for these applications. this is basicly the same diameter for the port into the motor and the throttle body. we could have built a custom intake with a single throttle body but this was the easiest way. I will try to post some real data once the engine has been tuned and run on the dyno.
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
