Injectors: High vs. Low
Old Jun 15, 2004 | 11:26 PM
version13's Avatar
Exhaust leak
I have 2 pairs of injectors one high impedance and one low impedance. The question is, cant these be used in the same system? One pair primary, one pair secondary? And finally, which would be better to put in each: low or high with primary, and low or high in secondary?
Thanks a Latte'
Old Jun 15, 2004 | 11:50 PM
BlackRx7's Avatar
Daily Domestic Killer
first you must figure out what impedence your wiring harness accepts.
86-87 had low impedence 88-93 had high
you can miss match different impedence injectors but you must install the correct resistors
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
The1Sun
Sep 7, 2015 10:21 PM
