Power FC I need a base map
Old Jun 14, 2004 | 05:07 PM
snagalittle's Avatar
I need a base map
I need to get a map for these mods. street port,dp,mp,catback,blitz smic,1300 secondaries,fuel pump, ypipe. What would be a safe boost 15 psi? Any clue on what kind of hp this setup will produce. I have just orderd my motor from jason along with datalogit and wideband. Thanks for the help guys.
Old Jun 22, 2004 | 01:44 PM
Slam Pig
yeah i need to know this exact thing....The base map that would fit our mods isnt available
suckerage
Old Jun 22, 2004 | 10:22 PM
luizajeff's Avatar
I would take a look at the maps already posted as there are a few that are close to what you have and use those as a starting point. It may help reduce the amount of time it will take you to tune, plus, compare the differences to help understand how changes in the maps apply to mods. Otherwise, just start off slow during the tuning process and move carefully from the low load to the high. Q? Do you have something to control boost now too? Many folks don't trust the PFC at all!
Old Jun 22, 2004 | 10:26 PM
luizajeff's Avatar
One more though, with those mods you'll have plenty of power with only 12psi and the lower boost will help your engine last a longer. Good luck and let us know how it all comes together!
Old Jun 23, 2004 | 12:17 AM
jpandes's Avatar
I am running very similar mods as you are. Check my sig. I'd be happy to let have my maps. JUST DON'T BLAME ME if your motor pops.
PM me with your email address. I can send you my .dat file or excel files of my inj & timing maps:
http://f2.pg.briefcase.yahoo.com/jpandes
John
Old Jun 23, 2004 | 06:37 AM
twokrx7's Avatar
Need more sleep
If you bought a motor etc from Jason he may be able to set you up with a starter map.
It's not too difficult to mod a stock PFC map for starters. Once you get it all installed, just pull your stock PFC map and send me a PM, if you email your map to me I can set it up to get you started and email it back to you.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
