problem installing cd player
Old Jun 5, 2004 | 10:12 PM
91mazdarx7's Avatar
i installed a sony cd player in my 91 rx7 coupe it works but how do i get the power antenna to go up and down
Old Jun 6, 2004 | 02:04 AM
esebueno's Avatar
there should be a wire for it
the thick black one that plugs in the back and has a silver tip (i think thats what it is)
then to SUPPLY POWER to it....you gotta make sure to connect the wire for it from your old harness to the new one (i think the new decks usually have it as blue w/ a white stripe or somethin)
Old Jun 6, 2004 | 04:32 PM
gz91rx7's Avatar
the fc has a negative power antenna trigger, and your new sony has a positive output(blue/white wire) you will need to use a relay to switch the blue/white to a negative output.
Old Jun 8, 2004 | 06:50 PM
91mazdarx7's Avatar
where could i get the relay at
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
