Knightsports EBSIII
Old May 27, 2004 | 01:20 PM
blkrx007's Avatar
Question Knightsports EBSIII
I just installed a Knightsports EBSIII and the instructions for the modes and settings are in jap-lish (just enough English that you understand how to install it but not how to run it)
Can anyone help me with the settings, modes and adjustment of the w - n ****?
Any help would be great!!!
Matt
Old May 27, 2004 | 03:55 PM
racer1's Avatar
flying apex seal
And what is the EBSIII??
Old May 27, 2004 | 04:12 PM
Raziel's Avatar
Womp Womp
maybe jason from jt-imports can help you. But what is EBSIII?
Old May 27, 2004 | 04:37 PM
PVerdieck's Avatar
I'll bet it is a Boost Controller, Electronic Boost Sequencer, or something...
Old May 27, 2004 | 05:27 PM
PVerdieck's Avatar
I was right! Electronic Boost Stabilizer
Ouch, its not cheap! JT-Imports has it for 975
Holy crap! Look at that harness. It must be tapping into the stock ECU harness...
All that for boost control...
Now that is waste of money. A boost controller should not cost as much as a PowerFC.
Did you get the column mount? Only 245!
Old May 27, 2004 | 05:47 PM
adam c's Avatar
Cheap Bastard
Maybe that explains why the Knightsports high flow cat was so expensive.
Old May 27, 2004 | 10:54 PM
blkrx007's Avatar
$232+ $30 on e-bay direct from Japan (used but in great shape) I am using it with an M2 ECU. Didn't get the column mount. Easy install with the factory harness, just wish the instructions were in english. I think JT-imports is a little high on this.............
Old May 27, 2004 | 11:39 PM
seanfd3s's Avatar
airplane apex seals
i have the same thing and would like some help as well. though i have to change the harness to my 2000 ecu or does some one want to trade or buy it to same me trouble makeing it fit my ecu??
wthx100
11
Oct 1, 2015 10:23 PM
