wastegate actuator ok?
Old May 27, 2004 | 09:50 AM
zullo's Avatar
Obsessed
While trying to diagnose an overboost problem...
I have hooked a pressure tester up to the wastegate actuator to test its function.
The actuator arm doesn't move at all until about 9-10 psi are applied. It takes significantly more pressure to extend it fully (my gauge only reads up to 10)
Is this a valid way to test the action? Do those results sound right? If not, can just the actuator be replaced? I don't see a separate Mazda part number for it.
Thanks
Old May 29, 2004 | 01:06 AM
teamstealth's Avatar
Ozone Depleter
I tested mine like that. she popped right open at 7psi, and shut closed nicely anytime i applied vaccuum to the line. I do not know the part #'s though.
Old May 30, 2004 | 10:28 AM
zullo's Avatar
Obsessed
ttt
Simpler restatement of questions:
1) At what psi should the wastegate actuator begin opening, and at what psi should it be fully open?
2) Is applying static pressure with a pump a legit way to test the action of the actuator?
3) Can the actuator be purchased by itself? I don't see a separate part number.
Old May 31, 2004 | 07:54 PM
Mahjik's Avatar
Mr. Links
Hey!
I didn't know you were having problems. It's most likely your new open intake giving you the boost spikes. Most people I've seen usually start getting boost spikes once they open up the intake from the stock airbox (or modify the stock box).
I doubt there is anything wrong with your wastegate (aside from it reacting too slow which is where those electronic boost controllers come in handy).
According to the troubleshooting site, the actuator should start opening at 8 PSI: http://www.autosportracetech.com/RX-...leshooting.htm
I've never needed to test mine so I'll have to go along with what the site says.
As far as the parts, talk to Ray:
Malloy Mazda
1-888-533-3400
Talk to Ray Crowe
He can tell you if you can order it separate or not.
Old Jun 1, 2004 | 12:22 AM
zullo's Avatar
Obsessed
Thanks Mahjik - not really having problems, but yeah the boost is higher than I like and the PFS purple box is having a hard time keeping it down...
Bought a MityVac and have been going through all the turbo-related vacuum lines. (Fantastic tool!) Found two leaks so far, and was suspicious of that s-l-o-w movement of the wastegate actuator.
Sounds like it is probably healthy though...
Hey, feel like helpin' out on a silicone hose job? ;-) I just ordered the kit from Mazdaformance after feeling how brittle all my vacuum lines are. Should be fun.
Old Jun 1, 2004 | 07:32 AM
Mahjik's Avatar
Mr. Links
No problem as long as it's not this coming weekend. I'll be out of town at the in-laws for the weekend. If you can wait, I'll help!
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
