Fuel pump big enough?
Old May 25, 2004 | 07:22 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
I'm about to get and install a rebuilt Nikki carb. The carb has:
Primary ventury: .980 inch inside diameter
Primary fuel jet: #160
Primary air jet: stock size
Secondary Ventury: stock size
Secondary fuel jet: #190
Secondary air jet: stock size
I have a Purolator fuel pump, 2-3.5 psi, 1700 cc/hour. The pressure is basically stock, the volume is more than the 1400 cc of the stock pump. Will this pump be enough to keep the carb supplied with the fuel it will be able to consume, even at WOT? Engine has a RB size streetport.
Old May 25, 2004 | 09:15 PM
cdrad51's Avatar
listening to advice from the gurus now
Old May 26, 2004 | 09:18 AM
Siraniko's Avatar
RX for fun
just get a holley red....IMHO carter pump is a JUNK-so much incosistency in the pressure. little louder than a carter but you will end up with a loud exhaust anyway...so who cares.
Old May 26, 2004 | 08:09 PM
cdrad51's Avatar
Thank you Wakizashi.
Anyone else's input?
Old May 26, 2004 | 08:43 PM
FB II's Avatar
i have a holley red i'll sell you. it's been great, i just need more flow now for the turbo setup. i have the pressure regulator with it too. pm me if your interested.
-zac
Old May 27, 2004 | 01:53 AM
cdrad51's Avatar
Thanks. If I need it I'll shoot you a PM.
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
