Going to the track need advice.! plz?
Old May 21, 2004 | 02:44 PM
derty's Avatar
Going to the track tonight and need some advice on tire pressure I did a search and got answer between 17-27 psi in the rear. I am on some crappy Kuhmo's! I want to just get rid of them but will just wait till they wear out. What pressure should I be running? Thanks everyone.
Old May 21, 2004 | 04:37 PM
reza's Avatar
dual oil cooler, bigger intercooler. bigger radiator. new radiator fluid, change oil, tranny oil, diff oil.
wash car.
run about 36psi hot tire pressure to answer your question.
Old May 21, 2004 | 04:38 PM
Snook's Avatar
Tony Stewart Killer.
sounds exciting bro run the car to full potential
People say to run much lower pressure but I spun a lot more on the kumhos on my last fd when I did that. If you have no way of filling up the tire again start off at normal and then take it down a few each run.
I think it was 20 where I just spun all the way through 2nd. Id try 28 and then 25
Old May 21, 2004 | 04:41 PM
Mahjik's Avatar
Mr. Links
I believe he's going to the "Drag" track not a "Road Course" track.
Old May 21, 2004 | 04:45 PM
derty's Avatar
Thanks for the input guys, but don't know about the 2nd responce lol but helpful info for me later when I do my tracking event in July -=]. I think 27 psi would be a good location for my pressure. Hopefully if I need to fill up I will just run to the gas station and do it and get back in. I will post results sometime tonight or early tomorrow. Once again thanks!
Old May 21, 2004 | 05:33 PM
reza's Avatar
ahhhh...i see..."track" is a road course.
strip is the drag strip.
someone should get it right.
Coochas
44
Nov 5, 2019 11:08 PM
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
