Suspensions techniques springs too short?
Old May 19, 2004 | 10:36 AM
bouis's Avatar
I realize that these springs are supposed to lower the car, but they seem to be too short. I don't need a spring compressor at all to install them, in fact, they seem to be too loose, with about 1/2" of free room.
My new tokico shocks did come with spacers, but not instructions, so I don't know where to use them. This have anything to do with it?
Thanks in advance.
Old May 19, 2004 | 10:37 AM
bouis's Avatar
Also, should I cut the bump stops?
Old May 19, 2004 | 10:58 AM
bouis's Avatar
Okay, apparently this is normal with lowering springs. I still don't know what to do with those damn spacers.
Old May 19, 2004 | 11:02 AM
front or back??????????????????????
Old May 19, 2004 | 11:07 AM
bouis's Avatar
Sorry, front struts.
Old May 19, 2004 | 11:10 AM
the fronts are going to be loose, ones u put pressure from the car they will be o.k p.s are the back ones o.k?
Old May 20, 2004 | 07:55 AM
stevehilde's Avatar
What lutherx7 said. They'll look loose when they're outside the car, but once you get them in place, the upward pressure from the control arm tightens everything up real nice. You'll sort-of have to compress the strut assembly to get it in there, and you'll say to yourself, "OK, that makes sense".
Old May 20, 2004 | 12:34 PM
9d7gst's Avatar
Boss**"You scare customer"
You also have to cut the bump stop when using lowering springs. Im not sure how long the stops are now, but if there are more than 2 ummmm "ribs" ,"bumps"?? lop one off for the heigth taken away. Ah that makes no sence. cence. scence. I dropped out of highschool. To become a mechanic. Why.
Old May 20, 2004 | 04:25 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I dont remember my front lowering springs being loose at all....
I have B&G springs, which, at the time I bought them, had the lowest advertiesed drop at 1.4in all around
Old May 20, 2004 | 06:04 PM
S2-13BT's Avatar
My lowered springs are captive at the front as well. I have used springs that aren't and it's not a problem. As has been said, once the car is on the ground everything tightens up. If you were to get airborn, then maybe it'll be an issue!
