ratsnest and electrical connectors
Old May 16, 2004 | 09:21 PM
z8cw's Avatar
I did a search and nothing came up....
My question is what you guys did after eliminating the ratsnest. Did you leave all the wire connections in place or cut them. I couldn't find a place where to obviousely disconnect them.
I personally like to get rid of them since it will clear up the area to work on the injectors and will probably look cleaner even with the intake manifold on.
Any experience or opinions
Thanks
Claus
Old May 16, 2004 | 09:51 PM
Broken09's Avatar
I am becoming...
Some people cut them others don't. I think it's all a matter of your preference.
Old May 16, 2004 | 09:53 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
I tore down the wiring harness and completely removed unused wires and plugs. Don't recommend it if you don't know what you are doing though (please, no offense). You can also just cut off the plugs and individually wrap the ends.
Old May 17, 2004 | 05:00 AM
FierceAlien's Avatar
Registered User
i had sodered in resisters into the plug's to fool the ecu. stock ecu. i forget what kind of resisters they were. but i believe its some where on the fourm. ran across it befor. And if you so decide u can reverse it later on.
Old May 17, 2004 | 01:43 PM
c00lduke's Avatar
I laso unwrapped it and pulled each line out, but it can get tricky if you dont have some exp but i would say it really doesnt get hard till soemthing goes wrong and you have to start trouble shooting.
Old May 17, 2004 | 11:36 PM
z8cw's Avatar
Thanks for your help
Old May 18, 2004 | 01:05 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Agreed. I learned ALOT about that harness doing this project!
Old May 25, 2004 | 11:50 PM
Huero's Avatar
Anybody got pictures on the wiring harness after this process???
Old May 26, 2004 | 01:03 AM
c00lduke's Avatar
I can have some soon
Old May 26, 2004 | 09:03 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Me too!
