Road Racers gurus. prep recomendations?
Old Nov 5, 2001 | 01:19 PM
Smile Road Racers gurus. prep recomendations?
For all the 3gen road racers , recomendations on preparing a car for road racing, on cooling, suspension, shocks, power, weightness, aligments, tires and wheels, electronics, etc.
Going against 911 porshes turbos and non, supercharge rabbits, mitsubishi eclipse turbo, nissan 300 twinturbos, etc.
Something like a Gt3-GT2 class.
Pedro.
Old Nov 7, 2001 | 01:18 AM
racedriver's Avatar
I've been road racing for 4 years now with my FD. Here's what i've done. You might want to check what is allowed in your class, unless you are in open class, which means you are better off to buy a tube frame car.
must do's
K&n filter
gut or change thermostat
install ford griffin rad with custom silicone hoses.
lower temp plugs
gut or change pre cat
go non sequential and open wastegate to 1.24(you will have probs)
racing pads
open exhaust with dynomax muffler
929 master cylinder
pulleys
I run gab super r's with 650 eibach's frony, 450 rear.
I run mazda motorsport fr.swaybar, stock rear bar
fiberglass hood, t78 turbo, F40 brembo front brakes,2.85 :1 pedal ratio(rock hard brakes) modified stock, intercooler, K&N filter, full cage ,lengthened adapter for momo wheel, rear battery, lexan rear window, glass doors, trunk, 3.5 exhaust, additional injectors, power FC, 94 supra rear discs, corvette single calipers, bosch 911 turbo external fuel pump, 26 gallon cell, close ratio tranny with straight cut gears, speedline 17 inch wheels 8.5 &9.5 should be bigger, M2 rear suspension, ACt clutch, M2 flywheel. All these mods and a newer porsche 911 turbo is still a bit faster. They have more torque off the corners . I will dyno tune this year
and hopefully be quicker.I've spent $30,000 on the car. when it was stock it won the 98 western canadian championship (No porsches) but as an unlimited car its hard to beat a purpose built Tube frame car.
Old Nov 7, 2001 | 01:27 AM
finky's Avatar
I think the one in your attachment will work just fine
Old Nov 7, 2001 | 01:43 AM
must do's
K&n filter
lower temp plugs
racing pads
929 master cylinder
pulleys
how long did you wait for your momb adapter with spacer to come? I''m still waiting after 3 months for mine
Old Nov 8, 2001 | 02:37 PM
Thanks for all the recomendations !!!!
Old Nov 8, 2001 | 03:07 PM
Old Nov 8, 2001 | 03:09 PM
Single7's Avatar
Hi Racedriver,
Did you change out your rear brakes? Could you please elaborate on your 94 supra rear discs and corvette single calipers. Thanks -- Tommy
Old Nov 8, 2001 | 03:49 PM
Old Nov 9, 2001 | 12:54 AM
racedriver's Avatar
For the rear brakes I use a 94 front supra turbo rotor, 1.1 thick, about 12.6 dia.
bring it to any brake shop and enlarge the center hole to that of the rx7. Then machine .1 off the thickest side of the rotor. The caliper is off the back of a 99 corvette. it is a single piston and made for a 1 inch diameter rotor. I found a rebuilt one for $60 . You need to fabricate a mount.
This mod is usefull for a racecar to balance out a front big brake kit. The bigger diameter rotor gives more leverage and better cooling. In my experience big 4 piston rear calipers are too much rear brake and require a limiting valve. They also displace more fluid which gives a soft pedal. Also with a limiting valve and more fluid displacement the ABS doesn't work properly as it is designed to a certain volume of fluid . I drilled a hole near the top of the pedal arm and connected it to the master cylinder with a chunk of about 1 inch aluminum. this with a 929 master cylinder will give you a rock hard race car pedal.I use the F40 front caliper, 38/44mm.
wouter Bouman
Old Nov 9, 2001 | 02:06 AM
1FooknTiteFD's Avatar
Ghost Ride the Whip
All the japanese tuners (FEED, PANSPEED, RE AMEMIYA) all choose generally the same approach. first get coilovers, then get race tires, and get racing bushings all around for your car. For cooling and power, go single turbo, take out the non essentials like power steering, AC, and the airpump and relocate the battery to the rear cabin bin. you want as much space freed up under the hood as possible so that there is more room for the hot air to escape under the car. Get dual oil coolers, in japan they custom fabricate the FC middle oil cooler for an FD in road racing. get a radiator upgrade, and also brake and engine upgrades. Get a full rollcage to increase chassis stiffness and handling and safety. Get a steering wheel, racing seat, and 5 point harness. Tear out the interior and get a vented hood, a nice functional wing, and all the other power essentials. For road race you probably need only about 340-350 rwhp and you will be sufficient. If you really want to be competitive your most primary concern is to get your car to run 2 to 4 hours of hard driving, not high horsepower or handling. Of course in the end, the determining factor for winning races is still driving skill....
Old Nov 9, 2001 | 05:28 PM
Thumbs up Tranny
Hi racedriver.
Where did you get , the close ratio tranny with straight cut gears?
Thanks
Pedro
Old Nov 9, 2001 | 05:59 PM
Thumbs up Tranny
Hi racedriver.
Thanks
Pedro
Old Nov 10, 2001 | 11:00 AM
racedriver's Avatar
a friend i know had a 3 rotor fc and had the tranny built by houseman autosport. They weld syncos on jerico gears and make their own shafts. They do this for several types of cars. He then bought an imsa rx7 which came with a saenz race tranny. He paid about $4000 for the conversion. When i bought it i simply put the bell housing and tailshaft of the fd on the fc casing, which is basically the same as the fd. the gearing is close ratio and it should have no problem handling 600 hp.
wouter
Old Nov 10, 2001 | 04:24 PM
LittleBlue's Avatar
Well, I now know what my FD wants to be when it grows up "racedriver".
Where did you get the lexan rear window? I have been looking for one. Is your slotted for air to pass through?
Old Nov 10, 2001 | 08:50 PM
almost99's Avatar
1FooknTiteFD
Where do you get race bushings for an FD?
Old Nov 11, 2001 | 11:34 AM
racedriver's Avatar
I had a window taken out of a trunk lid to make a mould of the trunk in fiberglass. I took some thin card board and laid it out on the rear window and cut it to size. Then i took that to a plastics shop and had them cut a piece of lexan to that size. Make sure you get them to cut it as it is very hard to do. Then i used rivets all the way around to keep it in shape and in place.
Mazda motorsports makes and sells harder rubber bushings but they are extremely expensive. M2 sells them too i think. For a purpose built race car i'd probably use solid rod/ heim's ends.
Old Nov 11, 2001 | 01:11 PM
RX7-2JOCK's Avatar
ZZzzzzz...PHshshshssshh
Do you have a FMIC.......If so, I was told to spray the IC down before you race with some cold water, it helps reduce the heat......
Old Nov 11, 2001 | 10:29 PM
racedriver's Avatar
i have a trust smic . I haven't sprayed it because the races are too long. In road racing they are between 30 min to 1 hour.
Old Nov 12, 2001 | 11:33 AM
Hi race driver and 1fookntiteFD.
What is the best shocks for the money for road racing? with a single adjustable and rebuildable?
What are your'e car weight ?
Old Nov 12, 2001 | 10:49 PM
racedriver's Avatar
The best value in my opinion is the gab super r's, available at m2.
Bilstein is also one of the best, but not adjustable. Buy direct and they will match them to your springs.
M2 sells Advance Design for about $2000. Very adjustable
Tri-point sells Penske's aluminum bodied shocks at a whopping 4000.
I would go with Bilsteins or Gabs.
With windows and stock panels, and full cage, my r1 weighs 2700 lbs. Now that it has a fiberglass hood, door skins , trunk, & lexan rear window I estimate it weighs 2500 lbs.
Wouter
Old Nov 13, 2001 | 11:53 AM
Hi racedriver.
Yes, I have seen many roadracers using gab's, taking advantage of price, ajustability and that can be used with hi spring rate a requirment for road racing.
You have save some good pounds, as weight saving is a very important issue you turn faster, acelerate quicker, and brake in shorter distance.
Thanks
Pedro
Old Nov 13, 2001 | 12:00 PM
Hi racedriver.
Thanks
Pedro
Old Nov 13, 2001 | 08:50 PM
racedriver's Avatar
I have a fiberglass drivers door available that needs some sanding, and two fiberglass front fenders, L&R . $100 US for door, $150 for fenders.
Are you planning to build a race only car or a race/ street car.
A guy in the Florida rx7 club has done a 93 up quite a bit, strictly a track car.He's got pics & info on their site about his race in Daytona.
wouter
Old Nov 13, 2001 | 10:51 PM
LittleBlue's Avatar
Check your PM racedriver
Old Nov 14, 2001 | 12:07 PM
hi race driver.
Are the fender price 150 each or both? do you make those ?
Some photos for the door and fenders?
Yes, the proyect is to make only race car.
May you give me the web site of the daytona racer?
Thanks
Pedro.
