Power FC Power FC and Double Throttle
Old May 5, 2004 | 09:37 AM
CapitanCombo's Avatar
Will it continue working with the PFC installed?
and also, will the car be kept in limp mode at the power up as with stock ecu?
I am about to remove the DT assembly, can I remove the solenoid and plug the vacuum hoses? or have I to put a resistor in the connector?
Old May 5, 2004 | 11:46 AM
NewbernD's Avatar
Tequila? ..it's like beer
Re: Power FC and Double Throttle
The PFC controls it fine, but it could care less if it's been disabled. You'll be fine, no resistors needed.
Queppa
Nov 18, 2024 03:47 AM
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
