Timing
Old May 4, 2004 | 10:49 PM
totallimmortal's Avatar
Is that thing Turbo?
Timing
Is there anyway to adjust ignition timing without a stand alone? I know alot about cars but very little about timming.
Old May 5, 2004 | 12:04 AM
bump
Old May 5, 2004 | 12:08 AM
trickfc's Avatar
you can adjust timing with a timing light. ( use a timing light that has battery connectors and clamp on spark plug wire, not one that just has clamp)
look at factory manual at fc3s.org under engine electricals to see picture of timing marks on main pulley. also make sure idle is at 750 and jumper the initial set coupler, which is explained in the manual
you have to adjust CAS and make sure leading and trailing marks are lined up right. its same as adjusting timing on piston cars w/ distributors, but you have to check 2 different coils.
if you cannot bring it into spec, then you have to take out CAS and re-install it by factory manual instuctions
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
