Rear wheel studs "longer needed"
Old May 4, 2004 | 01:07 AM
Tripple 7's's Avatar
Does anyone make longer wheel studs for the rear.
I am running 92 NSX wheels on an 88 vert, and the stock studs are just shy by 1/4 lengh of the lug nut, I would like to have thread contact on 100%. The fronts are just fine.
The shoulder on the rear studs are longer than anything I have matched up soo far. Someone had to make some longer ones for racing but whom?
Old May 4, 2004 | 02:28 AM
RETed's Avatar
https://www.rx7club.com/search.php
2nd gen specific
Keywords "wheel stud"
duh
-Ted
Old May 4, 2004 | 04:04 AM
FDreaming's Avatar
S4 now S6 soon...
Re: Rear wheel studs "longer needed"
got pics?
Old May 5, 2004 | 03:21 AM
Ted, yes I have done the search.
Im looking for rear studs with the same shoulder as stock which is aprox 1 in. long. Rather than these " shown above" aftermarket 1/2 in. long shoulder type.
Old May 5, 2004 | 03:39 AM
J-Rat's Avatar
Alcohol Fueled!
This should be good... Tripple 7s isnt your typical poster...
RETed's Avatar
The ARP ones do not look like that when you order the proper part number.
I dunno what you mean by "shoulder"?
-Ted
Old May 5, 2004 | 04:07 AM
Technically studs have a two shoulders, one where the knurling is located on and one at the back, where is seats against the hub. I’m referring to the knurled portion or area.
On the stock studs I have. The knurled area is aprox. 1 in long, smooth with a 1/4 or 1/8 in. knurling band offset in the middle which is unusual amongst various manufacturers. I have looked for a similar replacement from another vehicle and all have had the wrong shoulder length "knurled area".
http://fc3spro.com/TECH/MODS/RT/lstuds.htm
These listed here just look like standard studs which are readily availible.
But I could be wrong.
Old May 5, 2004 | 01:53 PM
Silkworm's Avatar
Has been.. hangin' around
You've lost me.
I run ARP Camaro studs, they have the exact same knurl diameter and thread pitch, and are approximately 1" longer than stock, which works great on my race car.
PaulC
Th0m4s
Feb 26, 2019 02:04 AM
Marty RE
Aug 17, 2015 09:36 AM
