brakes not working!! help!!
Old May 3, 2004 | 11:09 PM
1990_whitecomet's Avatar
hey guys!. i just got my single piston changed to a four piston.. swEet.. but sUcks cause some how my brakes are now not working or responding.. when i tried stepping on the brake pedal to get some pressure into the system.. my engine bogg with it idling low also with no pressure at all while i've pumped it many time already.. but i only got the driver side four piston in.. i'll get the passenger side in tomorrow.. its dark and i can't see no more.. but hUumm whats making my car not want to brake now..all my brake fluid are in.. its not low or anything at all.?? and why is my engine rpm dropping as its going to die.? (or is it cause i onlyhave one side in, but i think it wouldn't matter.? ) anything.. i searched but nothing was related to what i have here.. anyways thanks guys..
Old May 3, 2004 | 11:16 PM
frestylereaction's Avatar
Rotorless
ummmmmmmmmmmmmmmmmmmm .... WHHATTTT
first, dont drive the car with mismatched calipers....that is so unsafe and stupid and so many other things...it will endanger you, the car, and anyone else on the road...why would you think about doing that!?
second...did you even BLEED the brakes....
wtf is with all these 15-17 year olds on the boards dicking around with these cars...breaking ****..
Old May 3, 2004 | 11:26 PM
hahaa.. it was just rolling around in my yard.. it what went 0-1 mph..ehehe.. i was just steping on it if its responding.. im not going to take it on the road yet man.. commOn!.. and man hahaaa sorry you didn't get a seven when you were my age.! wasn't your luck i guess.. but i just wanted some input!.. thanks!..
Old May 4, 2004 | 11:39 AM
90RX7convertible's Avatar
The brakes need to be bled real good. There is probably lots of air stuck in the line right now.
josef 91 vert
23
Sep 3, 2015 11:20 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
