RX-7 Cargo net
Old May 3, 2004 | 12:38 AM
Sgt Fox's Avatar
Stigulus Moderatorai
RX-7 Cargo net
was wonding how manntis put that cargo net in pamala. and what kind of net did he use?
Old May 3, 2004 | 12:51 AM
Manntis's Avatar
add to cart
generic minivan cargo net I bought at Canadian Tire (sort of a wal-mart for car stuff) - a loop at each corner, just the right width.
It comes with 4 plastic ***** to mount the net - I only needed two.
I removed the two screws in the front lower corners of the triangular plastic window trim in the hatch area. Using two of the long screws that came with the net I screwed in the two plastic ***** for upper mounting points.
I then unscrewed the metal bar across the front of the carpet area. I carefully folded the net in half, careful not to distort its shape by tugging, and found the centre. I laid the centre across the ridge in the carpet and screwed the bar back in place.
Then I just had to hook two loops on eack side onto the *****.
This not only makes a neat looking cargo net but provides a pocket between the net halves for carrying loose papers. Ever been driving down the road with a few sheets of paper on the passenger seat? Ever have those papers blow around? Stick em in the net pocket and you're fine.
NO drilling, NO cutting, fully reversible, and cost me about $4 for the net.
Old May 3, 2004 | 12:55 AM
Sgt Fox's Avatar
sounds good, do you have any more picture of it? looks like i'm off to crappy tire tommorow!
Old May 3, 2004 | 01:27 AM
Manntis's Avatar
add to cart
Just these ones:
Old May 3, 2004 | 08:21 AM
LongDuck's Avatar
84SE-EGI helpy-helperton
Ouch. That last picture still hurts. Net held up well, though!
Old May 3, 2004 | 08:37 AM
Bolox's Avatar
what happened?
Old May 3, 2004 | 09:52 AM
Directfreak's Avatar
I am a Jeeper Now.
I still cringe everytime..
Old May 3, 2004 | 10:05 AM
rx-7ames's Avatar
i have a rex that looks like that. it was rolled 4 times! ouch is right. i got if for $300. the engine only has 300 miles on it so i got a good deal!
The1Sun
Mar 18, 2018 11:08 PM
Project88Turbo
Aug 29, 2015 02:23 PM
betes
Aug 25, 2015 05:09 PM
sYnth.
Aug 19, 2015 06:27 PM
