Clutch fluid??
Old May 2, 2004 | 06:13 PM
kboneRX7's Avatar
Question Clutch fluid??
I think i need some clutch fluid in my 2nd gen. Rx-7.
Im not for sure where to put it , or even check to see if i need it! helppppp.
Old May 2, 2004 | 06:18 PM
Mike 240SX's Avatar
Ore wa lonely driver.
D'oh I was trying to be a comedian but didn't work right. Delete me please.
Old May 2, 2004 | 06:20 PM
AcidShock's Avatar
Eet fase
Come on now... he is just a newb.
Clutch fluid resorvoir is on the far right corner of the engine bay. Right behind the trailing coil. Unscrew the cap and fill it up with DOT3 fluid.
Old May 2, 2004 | 06:24 PM
cwsttu's Avatar
1.3L is not that small
look at the clutch master cylinder next to the brake master cylinder... its just like checking your brake fluid or p/s... just take off the cap and make sure it falls between the lines... so pretty much its in the very top corner of the bay on the drivers side, cant miss it cause there are only 2 units there that come out of the firewall from the gas/brake/clutch pedal area...
Old May 2, 2004 | 07:12 PM
Project84's Avatar
Open up! Search Warrant!
If you don't know where it is or even how to add the fluid, what in the world makes you think you need more? Did you just wake up one morning and decide you needed clutch fluid?
Old May 2, 2004 | 07:21 PM
Fritz_X's Avatar
Project84 If you don't know where it is or even how to add the fluid, what in the world makes you think you need more? Did you just wake up one morning and decide you needed clutch fluid?
Maybe his clutch didn't work right? . Just a thought.....
--Fritz
Old May 3, 2004 | 05:58 PM
kboneRX7's Avatar
thank ya thank ya, i got it fixed!
Hipsiguy
Sep 14, 2015 05:25 PM
Evan Kurtz
Sep 13, 2015 08:40 PM
