fuse block
Old May 2, 2004 | 05:36 PM
riceburner1r2001's Avatar
fuse block
i have a 88 turbo II and i have checked all my fuses in the motor compartment and fine. now inside the car at the fuse box my illum, antenna, room, hazard, and stop light up. the rest of the fuses dont. what could be the problem be . i do have the motor out but that shouldnt be the problem thanks guys if u can help
Old May 2, 2004 | 05:38 PM
WAYNE88N/A's Avatar
need to turn the ignition on, maybe?
Old May 2, 2004 | 05:42 PM
WAYNE88N/A's Avatar
those fuses you mentioned get their power from the hot BATT source (they're also all at the top of the fuse block, right?)...the remainder get power from the ignition sources (IGN1, IGN2, START, and ACCESSories)
Old May 2, 2004 | 06:17 PM
now i have fixed some of it and thank you wayne. i have no power for my stereo at the fuse n the car i dont get any power when i use a test light and only 1 of my threee fuses work in the very back of stereo.
FC3S Timmy
16
Oct 3, 2015 01:08 AM
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
jarjarbinks
Sep 25, 2015 11:03 PM
MidnightOwl
Sep 25, 2015 10:24 PM
