car smokes when starts up`
Old Apr 26, 2004 | 10:02 AM
gerbraldy's Avatar
wtf's a piston
I recently just put two staright through mufflers on my stock exhaust, welding the mufflers on to the original pipes which I welded 1/8" steel plates over the rips in the original pipe. I would have got whole new pipe, but it was 1:00 am at my buddies shop, so now stores where open. Every once in a while when I start my car up, there will be very light smoke coming out of my mufflers for abut 1 minute, then it will stop. It happens sometimes, but not always. It didn't do this before I put on my mufflers and patched some wholes. I think maybe my cats are clogg'd, and or rotted. If anyone could give me a little info on what the problem might be I'd be very apprecitive.
Thanks,
Old Apr 26, 2004 | 10:12 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
My GTU used to do that all that time once i switched to Straight-thru Mufflers..
As long as its a light blue smoke, I wouldn't freak out about it. If its bright white and smells sweet on the other hand....
Old Apr 26, 2004 | 10:56 AM
gerbraldy's Avatar
wtf's a piston
Whatever it is, I'm not worried about it too much. I'm putting a gtx engine in that thing soon, hopefully if I can't find a TII, thanks
Old Apr 26, 2004 | 12:13 PM
deltr0n`'s Avatar
Track Junkie
you SHOULD be worried! your motor is getting tired, thats a water seal, and its only downhill from there. dont drive it hard, it could go any time.
Kyo
Apr 13, 2019 09:24 AM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
pzr2
Aug 15, 2015 08:29 PM
